Changed oil before storage, change again before startup in spring?
Old Jan 31, 2004 | 08:04 AM
95LT1Z28's Avatar
Question Changed oil before storage, change again before startup in spring?
I changed the Mobil 1 oil in my Z before I put it into storage last fall. Do you think I should change the oil again before I start it up this spring or just change it at my next 2,500 mile interval?
Jeff
Old Jan 31, 2004 | 08:14 AM
Igniter's Avatar
Why would you change it? The oil is still brand new, just wait until you put your 2,500 miles on it before changing it again. The oil in there is just fine, do not worry.
Old Jan 31, 2004 | 12:31 PM
ROCKN SS's Avatar
I wouldn't change the oil again, however what I do after winter storage is pull the coil wire (or fuse for fuel pump to keep it from firing) and crank it for a while to get some oil circulating before starting.
PCLZ28
Dec 24, 2015 05:19 PM
jj71787
Jan 31, 2015 10:20 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
