changed my build up idea have some questions
ok ive decided to change my build up. instead of a 355 im going to do a 383. i found the kit fromadperformance. heres the link to it . 383 kit what i need to know is what else do i need to make this kit compatiable with my lt1. im going with some le heads i just have to talk to lloyde and figure out what to go with as in heads and cam choices. the intake will be ported and i planon switching to a 58 mm throttle body.
Re: changed my build up idea have some questions
ok im gonna start a list of what i need to get this built and running .
1. 383 kit with forged pistons
2. heads and cam
3. ported intake
4. 58mm throttle body
5. tune from madz28
6. ???
7. ???
8. ???
9. ???
10. ???
11. ???
do i need bigger injectors?
do i need the lt4 knock module?
i plan on spraying a 150-200 wet shot on it.
any more sujestions are apreciated
2. heads and cam
3. ported intake
5. tune from madz28
6. ???
7. ???
8. ???
9. ???
10. ???
11. ???
And 12,000-15,000 dollars ya ain't doing nothing with to make a killer set up,that doesen't break something everytime ya stand on it..The engine is only 1 part of the equation.
Ya need tranny,converter,rear end,wheels,tires,guages,drive shaft,TA, shocks and that's a start. There WILL be more.
Ya can make 600FWHP with Loyd's 3 set up what's up with the hose? That's about 480RWHP,Now you are getting real hard on the driveline if ya HOOK it and spinning don't go anywhere.
if you read my sig then you would see i already have a race ready bullit proof a604. i already have 373 gears and a nice set of mt's the post was for the engine only. if i have a tranny q ill post it in the tranny section.
Is that 3.73 gear in a 12 bolt or a 9"?
If it isn't its gonna say c ya when ya hook it.
Never herd of a a604 tranny.Have heard of a 4L60E,4L80E,700R4,2004R,Turbo 350-400,Glide,ect.
Just trying to be helpful but a 'tude is totally unnecessary,Mr.
You need to do more research on the whole combination IMO. BTW, what is an a604??
There's SO much more to it than the engine internals. The truth is, a "budget 383" doesn't exist after all the necessary upgrades and stuff that is going to break.
Originally Posted by SS MPSTR
Larry's trying to help you...as he's 'been there, done that' many times. There are a slew of parts you're going to need (the little stuff adds up fast), and an LT4 KM, bigger injectors and forged pistons should be on your list.
sorry about the a604 thing i was on the phone ordering a tranny for my g/f's eclipse from level 10 when i was typing this. i ment 4l60e
Been there, done that, and all I got was a lousy t-shirt
Deadbolt24
Jan 19, 2015 01:29 PM
