View Poll Results: Should I Change Valve Springs
Definately Change Them, Will see a substantial Re-gain in Performance
11
37.93%
Replace Springs because of High Milage--have to do it eventually
12
41.38%
Do it to blow 100 dollars
3.45%
Don't do anything....no gain in the 1/4...waste of time.
17.24%
Voters: 29. You may not vote on this poll
Change Valve Springs??
Old Jan 11, 2005 | 10:58 PM
  #16
"White Knight"'s Avatar
Re: Change Valve Springs??
Any place i can get some basic, standard LT1 valves for pretty cheap? Might do valves if they are bad-I think i'll take a look when i do the springs.
Old Jan 11, 2005 | 11:07 PM
  #17
Z28Nut's Avatar
White Knight -- Here's a link to Comp's spec page:
http://www.compcams.com/Technical/Cu...g/HTML/337.asp
I did have to pull out the inner damper springs for them to fit on the stock seats.
Old Jan 12, 2005 | 07:36 AM
  #18
BlkLT1Z28's Avatar
Originally Posted by White Knight
My power drops off way before 5grand, it's more like 4000 maybe earlier...at least that is the way it feels. I am going to dyno sometime if i don't figure it out.
well another bad part about it is that the LT1 will never sound or feel like a LS1 up top. If you have ever ridden in a LS1 Z or TA(I can bet you have) You will know that there top end is so much stronger and smoother. So when I ride in my buddy 98 Z then I go and get into my car, it feels like its dieing above 5000. But if you are losing power above 4000 then something is wrong. I just put a msd box on my car and that seemed to really clean up the way my car ran, especially up top. It may not be any faster, but it has a lot more response and the high rpm occasional miss is gone and it now pulls hard to the limiter. But i still feel like the springs are going crazy trying to keep the valves under controll. As far as a replacement spring, I just plan on getting some LT4 springs from a hot cam kit. There dirt cheap, they fit and I am no where near ready to do a motor in my car so putting springs that can handle .600 lift will be a waste b/c by the time I get around to putting a cam in my car those spring will also be worn. Hope this helps.
Old Jan 12, 2005 | 09:31 AM
  #19
TQdrivenws6's Avatar
Why not just get some LE1 heads for $750? Thats springs, retainers, etc plus a port job.
Old Jan 12, 2005 | 11:01 AM
  #20
rskrause's Avatar
Moderator
130K miles is a lot on valve springs for a performance car. But the only way to know if they are good is to take them out and test them. At that point, you might as well replace them.
Rich
Old Jan 13, 2005 | 04:55 AM
  #21
93turbo5oh's Avatar
lt4 springs are $35 from scoggin dickey. why not do it? im getting ready to buy some and my car only has 80K on it and still pulls to 6000rpm.
Old Jan 13, 2005 | 11:38 AM
  #22
Yea once they are out you midaswell replace.
Really? everyone always says they are dirt cheap, but i could never finde them very cheap. I will look into it. If they are like $40 i will definately do it.
Old Jan 13, 2005 | 01:36 PM
  #23
93turbo5oh's Avatar
$32.95
http://www.sdpc2000.com/catalog/3533...Spring-Kit.htm
Old Jan 13, 2005 | 03:59 PM
  #24
Are the locks and spring caps the same as the LT1 or should i get those too? They are only like $21 together. You think they are any lighter?
Old Jan 13, 2005 | 05:27 PM
  #25
stereomandan's Avatar
Well, I just put in LT4 springs, LT4 retainers, and LT4 locks. The retainers and locks looked identical to the LT1's. I dropped a single LT4 lock, and used a lt1 lock in it's place and it was fine.
Maybe someone else knows for sure.
Dan
Old Jan 13, 2005 | 05:33 PM
  #26
I guess i midaswell just get them. it's only another 20bucks
Old Jan 26, 2005 | 01:49 PM
  #27
chevyguy3's Avatar
the LT4 retainers and locks are idential to the LT1s
Old Jan 26, 2005 | 08:36 PM
  #28
cat1055man's Avatar
I had a simular performance drop and found the cat converter had broken up inside and was plugging the outlet of the converter resulting in tremendous back pressure, major power loss above 3500rpm.
Old Jan 26, 2005 | 09:07 PM
  #29
I have a high flow cat installed it with the B&B exhaust system.
Old Jan 27, 2005 | 01:54 AM
  #30
1racerdude's Avatar
Make SURE you get the LT-4 retainers. I didn't and it cost me an engine. Dropped a valve @6000.
