change timing set?
Old Apr 15, 2010 | 10:39 PM
z28beast's Avatar
change timing set?
ok motor out of car..installing a comp cams 305..i have 100k on the clock do i need to replace the timing set? i called summit and they said 400 bucks..i dont have that kinda money rite now...what should i do? is there anything cheaper?
Old Apr 15, 2010 | 11:10 PM
MikeGyver's Avatar
You could do a Cloyes 3145 double roller and electric water pump cheaper than that, or just leave it alone unless theres a problem with it.
Old Apr 16, 2010 | 12:38 AM
RamAir95TA's Avatar
I would change it out with a new stock set. Make sure you replace both the chain and the sprockets.
Old Apr 16, 2010 | 12:12 PM
z28beast's Avatar
well its got 100k on it...and im changing the cam
Old Apr 18, 2010 | 05:33 PM
95Blackhawk's Avatar
Have you checked to see if the chain has worn out? Is there unacceptable slack?
Old Apr 18, 2010 | 07:03 PM
Stl94LT1's Avatar
He would also need to do a Gen II opti conversion on his 94 to run the 3145. Which includes a new opti, timing cover, opti wire harness, and opti vaccuum harness.
Old Apr 18, 2010 | 08:41 PM
pro94lt's Avatar
You can get a Cloyes timing set for 95 bucks at northernautoparts.com, Correct me if i'm wrong but I think they made them originally for GM.
Old Apr 18, 2010 | 09:54 PM
z28beast's Avatar
ok i pulled the cover off today and the chain does have slack...how do i measure if its too much?
Old Apr 18, 2010 | 10:45 PM
RamAir95TA's Avatar
Replace it anyway.
Old Apr 19, 2010 | 10:34 AM
IceMatrix69's Avatar
Cloyes makes a nice replacement chain and gear set.
Cloyes Timing Set
Old Apr 19, 2010 | 10:20 PM
z28beast's Avatar
Cloyes Timing Set
dude htf did you find that???? summit couldnt even find that set!
Old Apr 19, 2010 | 10:24 PM
dangalla's Avatar
dude just use a stock replacement set from gm, it is cheap and very rarely do they break, almost never compared to aftermarket junk
Old Apr 19, 2010 | 10:28 PM
z28beast's Avatar
Cloyes Timing Set
damn man thats for a1995+ i have a 94
Old Apr 19, 2010 | 10:42 PM
z28beast's Avatar
and where do you find them cheap??? everywhere i look its at least 300
Old Apr 19, 2010 | 10:48 PM
dangalla's Avatar
this is what i got from gmpartsdirect.com for a 94 z28
but i just got mine from the local chevy dealer
