Change o2s or not?
Old Jan 1, 2005 | 11:33 PM
pHEnomIC's Avatar
Change o2s or not?
I have a 97 z28 with 113k miles on it and it does run good but i am having gas mileage problems. Ive changed all the fluids/filters/plugs/wires/pcv valve/used seafoam/ and a few other things. I got some boltons and switched from a 160 stat to a 180 stat. I am getting about 13mpg driving suburban. I havent had a good chance to see how well it is on the highway. I don't lead foot it too much.
Well i was wondering if new o2s would make a difference or not? They may very well be the original ones in the car. Is there a good way to test the o2s without taking them out or is there any way to clean them?
Old Jan 1, 2005 | 11:36 PM
stereomandan's Avatar
Re: Change o2s or not?
At that milage, I would buy new ones.
You can get both for about $80-90 from www.gmpartsdirect.com if I remember correctly. It's only the front two that will affect your gas milage.
Dan
Old Jan 2, 2005 | 03:00 AM
Heatmaker's Avatar
Advanced Member
We all hate to buy parts that don't add Hp... but changing the 02's needs to be done... I went down to autozone and dished the cash out to get them...at 55K miles...it was a good decision, because my car is now running properly.
at 113K I'd recommend a change... Pull one out and see how it looks... if it's red...time for a replacement.
Old Jan 2, 2005 | 09:07 AM
Boosted_Z28's Avatar
Reading the O2 sensor voltages using a voltmeter or scan tool/data logger would be the best way to verify if they are responding properly. The appearance of the sensor itself is not always a true indicator of its overall condition.
Old Jan 2, 2005 | 10:46 AM
Heatmaker's Avatar
Advanced Member
If they looked like mine did they are.
Old Jan 2, 2005 | 10:49 AM
joecool72's Avatar
It makes sense to replace the O2s at this point, especially with new plugs and wires. When I changed plugs recently I found all four on the passenger side had gaps of .065 or higher. May have been related to a faulty O2. With all the tune-up maintenance you've done already I would for sure change the O2s.
Old Jan 2, 2005 | 01:07 PM
RansZ28's Avatar
As I have not done this - any instructions on how to?
Old Jan 2, 2005 | 03:20 PM
Bersaglieri's Avatar
Get the correct size wrench a yank it out. It will be tough, soak it with WD-40 or PBBlaster first. They are in there good!
Are there any differences in brands of O2's?
What are the correct 02 Sensor voltage levels, around 4.5X right?
-Dustin-
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
