Centerforce Dual Friction or Spec Stage 3
Old Feb 29, 2004 | 01:20 PM
  #16
Heatmaker's Avatar
Advanced Member
I've super-bled the clutch...even though I have the LT-1 non bleedable T-56 Hydrualic system... I used the mitty vac method and got all the air out the lines...then I even whent as far as replacing hte hyrdo system...that comes factory pre-bled....same issue. Like most guys I don't like wasting money or time...
Old Feb 29, 2004 | 01:34 PM
  #17
EviLZ28's Avatar
Hmm, I see all these guys having problems with the Centerforce clutch. I have one in My 95 T/A and ran 11:80's on nitrous. The clutch has 65000 miles on it and has been to the strip 4 times running M/T cheater slicks. Came out of the gates at 3500 rpms and was getting 1.5 0 to 60's. It never gave me a problem. But everycar and driver is different. I took the motor and trans out now as the odometer had 185,000 on it. The clutch shows a little wear but would still be good for another 20,000 miles.
Old Feb 29, 2004 | 01:50 PM
  #18
atljar's Avatar
Centerforce makes a GREAT clutch. Problem comes here....
With the stock hydrolics, they will not fully engauge and disengauge on many cars. Some get lucky.
You need to run an adjustable master like those that come with the McCloud street twin. You should be able to buy direct from McCloud, or www.lt1dave.com sells an adjustable stock unit which will also work.
You wont have any issues with the centerforce anymore.
Old Feb 29, 2004 | 02:00 PM
  #19
Zedzag's Avatar
Exactly! It's the hydraulics that can't fully engage/disengage the clutch.
Old Feb 29, 2004 | 04:34 PM
  #20
Heatmaker's Avatar
Advanced Member
There is also a new issue being brought up..about the Clutch Fork and Pivot T...
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
