CC918 valve springs with LT4 Retainers & Locks?
Old Jan 22, 2008 | 04:00 PM
95zsean's Avatar
I've searched and found nothing on this. So I was told that I could use the LT4 retainers,locks, and shims with CC 918 valve springs is this TRUE!!!!
Old Jan 22, 2008 | 04:30 PM
Vicious95Z28's Avatar
No. LT4 springs and retainers are of the typical sbc configuration. 26918 springs typically use comp 795 retainers and 613 or 614 locks (10*)
Old Jan 22, 2008 | 04:44 PM
95zsean's Avatar
These guys say they will work,look down to the valve springs.
http://www.cmotorsports.com/93-97-fbody/engine.html
Old Jan 22, 2008 | 05:34 PM
truedualws6's Avatar
They are wrong. Use the correct parts as mentioned above.
Old Jan 22, 2008 | 06:20 PM
95zsean's Avatar
795 are 7* locks also for BBC.
Old Jan 22, 2008 | 06:32 PM
lt1-xjs's Avatar
You can use LT1 locks and spring seats with the 787 retainer on that spring.
Old Jan 22, 2008 | 06:44 PM
95zsean's Avatar
But not the stock retainers? Are they to big around to keep the spring centered?
Old Jan 22, 2008 | 07:28 PM
lt1-xjs's Avatar
Too big to fit the spring.
Old Jan 22, 2008 | 07:34 PM
95zsean's Avatar
Thanks lt1-xjs,for your info.
Old Jan 23, 2008 | 07:49 AM
Nope, 795 are 10* retainers. They were originally designed to work on the bigblock beehive spring part#26120. The diameter around the top of this spring and the 918 are so close that people choose to use the 795 retainer with 613/614 10* locks for security. Heck I've got a set of em on a v6
Old Jan 23, 2008 | 05:37 PM
95zsean's Avatar
Your right I was looking at so much Info. last night that I got mixed up
I can't find the outside and inside diamater of the stock LT1 springs anyone know?
Old Jan 24, 2008 | 12:46 PM
Stl94LT1's Avatar
OD ~1.30
ID ~.90
Old Jan 24, 2008 | 08:33 PM
95zsean's Avatar
Originally Posted by Stl94LT1
OD ~1.30
ID ~.90
Thanks!!! Comp Cam says the 26918 is:
Top ID .650
OD 1.055
Bottem:
ID .885
OD 1.290
Thats why you can use shim and locks but not the stock retainers as they are to BIG!!!
Old Jan 25, 2008 | 11:00 AM
Stl94LT1's Avatar
I just looked at a stock LT1 retainer, and although I woudn't try. It is possible to tun these with 918's. Where the retainer meets the valve is .650. It may not be a perfect marriage of parts, but might just work. There would be .20 overhang.
Old Jan 25, 2008 | 08:23 PM
95zsean's Avatar
Thanks for the info. but i'm not going to take a chance. I've bought a different set of springs.
nikolt1
Feb 27, 2015 09:10 PM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
