cc503...stock rockers???
Old Mar 7, 2008 | 03:54 AM
TurboLsx's Avatar
Hey all, I am building a mild engine for a play truck...mostly for off-roading. I already have a stall converter and 4.10 gears... My question is, I see everyone claiming the cc503 is one up on the LT4 hotcam...is that with the hotcam on 1.6rr's and the cc503 on the stock 1.5's? I was looking at the hotcam b/c it really seemed to perform well on my cousins '96 T/A but I would rather save money on the cam setup if I can buy a cc503 without upgrading the rockers if it will perform as well or better than the hotcam. So basically, should I buy cc503, pushrods, and springs...or...the complete hotcam kit with 1.6's plus pushrods? Thanks for the input guys.
Old Mar 7, 2008 | 02:55 PM
BigBadBlack93Z's Avatar
you need to replace the rockers w/ anything other than the stock stamped ones no mater what cam you go w/.
as for something to offroad w/ you need to look at a custom cam, maybe pick something similar to the XE 4x4 grinds and move that over to an LT1 core, you'll need low end power that almost no LT1 shelf grind is going to have.
Old Mar 7, 2008 | 03:29 PM
Sparkz28ss's Avatar
stock cam for the 4x4 ... no reason to cam an off roader
Old Mar 7, 2008 | 05:29 PM
TurboLsx's Avatar
First, thanks for the suggestions guys. But everyone has their preferences and I definately want more than the stock cam has to offer. I know that with a decent stall and gears I can effectively run a mild cam in the trails. I live in central FL and the trails I play on arent rock crawler trails...these are more high speed trails. Also, this truck will be used for local mud drags from time to time just for fun. The truck wont be getting any miles on it to speak of. I am not building a race truck by any means...but I am not interested in low end torque, I keep my toys up in the powerband by getting it in the right gear...That being said, thanks for the input and help guys. So I take it that nobody is running a cc503 and stock rockers? I am used to the Ls1 and Ls3 engines and I am surprised that GM used a rocker this weak in the LT1's? You can run over a .600's lift cam on stock Ls1 rockers...
Old Mar 7, 2008 | 06:47 PM
its not that they used a weak rocker, its just that they used the cheapest rocker available. the engine can run, but you wouldn't want to push it, the rockers are a longer slot design but not a good long slot. at the very least get some comp magnums in a 1.5 self aligning, its a decent upgrade for $150.
Head over to chevytruckworld.com (or the google equivilent) and go to the pre-88 silverado forum, ask around there about the cam selection.
I ran a ZZ3 in a 4x4 and even w/ all the mid and high end power it made that sucker was a dog, you had to wind it out way to far to be fun on just a basic trail. 4.56's and 36" tires. That is a cam w/ similar characteristics of what you're looking at.
Old Mar 7, 2008 | 07:45 PM
95ltbird's Avatar
i dont know your preferences or what you want in an engine... but i recommend you check this out....
http://ls1tech.com/forums/showthread.php?t=836200
that should help you out and get you pointed more in the right direction
for offroading i would recommend the crane 227 cam
Old Mar 7, 2008 | 07:49 PM
mdacton's Avatar
Why? nothing wrong with them
I have run 119 mph on a stock engine from the factory with cam only.
Several people run them with 200# on the seat and 400 open.....I'm not afraid to use them
Old Mar 7, 2008 | 07:52 PM
mdacton's Avatar
We will be in 2 or 3 weeks.......the cam does not have that much lift anyway
Old Mar 7, 2008 | 08:02 PM
Chvywolf's Avatar
I've been running the 503 and stock rockers for a while ever since I found my old rollers took a crap and bent the alignment tabs. Butt dyno didn't feel a difference, and the tune didn't see one either. I would give you track times but they just started building it.
Old Mar 7, 2008 | 08:50 PM
TurboLsx's Avatar
Thanks for the input guys. I will check out the links. I think I will try the cc503 with the stock rockers. If I tear it up...oh well...at least it isnt my DD! I wont have it together and in the truck for a few weeks but I will try to remember to update this post with the results when I get it running. I will continue to check this post for any more tips or info. Thanks again everyone.
Old Mar 7, 2008 | 09:34 PM
different setups work better for some people than others. there were several factory in my build that caused me to have issues w/ stock rockers.
Old Jul 31, 2008 | 12:44 PM
TurboLsx's Avatar
Just an update...Im in the Marine Corps IRR right now and was activated in the beginning of May and just got back home. I finished installing the cam and valvesprings last night. Tonight I will try to get the timing cover back on and possibly install my carb'd intake manifold and distributor. I still have to convert the truck to an electric fuel pump and fan setup so it will be a few weeks before it is running. I will try to keep this post updated until I get the truck running.
Old Jul 31, 2008 | 09:03 PM
mdacton's Avatar
the car I put the stock rockers back on has about 75 passes on it...no problems as of yet, ran 12.40@ 110......runs consistant 12.60's
everything works fine
Old Jul 31, 2008 | 11:27 PM
TurboLsx's Avatar
Thanks for the update mdacton. Didnt get a chance to get anything accomplished tonight but will update when I do.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
