CC503 pushrods upgrade
Old Sep 30, 2008 | 06:35 PM
maybe2fast's Avatar
CC503 pushrod length guide plate height
I have the stock length hardened with the Impy HG and heads decked .007
CC503 cam with 1.6 promags and 918s 3 angled valves
would a 7.3 pushrod offer me a performance boost or leave well enough alone?
I am bringing this up because I have guideplates under the stock rocker studs and if I am not mistaken that raises the rocker higher...so should I compensate with a longer pushrod?
Old Sep 30, 2008 | 06:40 PM
mdacton's Avatar
Your wrong on a few things.
You want the geometry to be correct and a good pushrod. If thats good then there is no performance to be gained from a different pushrod
Old Sep 30, 2008 | 06:51 PM
maybe2fast's Avatar
I have good hardened pushrods, but when you put in guideplates it raises the position height that the rocker sits, compared to the height of the seat on the stud without guide plates.
the rocker is sitting higher than before the guide plates. and you use the factory length pushrod not compensating for the guideplate height.
Old Sep 30, 2008 | 08:32 PM
mdacton's Avatar
It does not move the rocker. The rocker is in the same place. The stud might be sitting higher but that does not matter @ .060" b/c the tip on the valve and the pushrod side are still the same.....
Old Sep 30, 2008 | 08:43 PM
ACE1252's Avatar
mdacton is correct.....the rocker "floats" on the stud.
Old Oct 1, 2008 | 05:53 AM
maybe2fast's Avatar
okay! I thought I wasn't getting my whole lift!
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
