cc503 parts list
Old May 7, 2009 | 05:14 PM
lightskindwonder's Avatar
cc503 parts list
I'm looking to do the full swap. Can someone provide the part #'s of decent & compatible parts I will need (i.e. lifters, 1.6 RR's, springs, push rods). I'm trying to get everything off summit. Thanks.
Old May 8, 2009 | 12:58 PM
should this package from summit work?
cam cc075038
rr's cca131816
spring kit: Lunati 73943k1lun OR 73815K2LUN (not sure of the difference or which would fit my specific application)...
just compared parts that would come with hotcam kit and tried to find something similar in price with a little more kick
Old May 8, 2009 | 05:54 PM
seawolf06's Avatar
Crane 10308 kit or PAC 1218/1518 springs with Comp Cams hardware (same as beehives).
The rockers are self aligning, so you don't need guideplates, but you have to check and make sure they will work with your springs. Most here will recommend the non self aligning RR and trickflow guideplates.
You should also consider ARP/Comp Cams studs and upgraded pushrods.
Old May 8, 2009 | 05:58 PM
LearJet's Avatar
Don't run self aligning rocker arms with the beehive springs. They interfere with the locks on the springs. Get non self aligning rockers of your choice and guideplates with hardened pushrods. Don't use regular pushrods with guideplates or they will destroy themselves from rubbing on the guideplates.
Old May 8, 2009 | 06:24 PM
ACE1252's Avatar
Should get you a good start.
http://www.ace1252.com/Z28_CC503_Per...ce_Buildup.xls
Google Drive location since Chrome is flagging my website as "unsafe" with no SSL certificate.
https://drive.google.com/drive/folde...bSv3zH4uKbrVl3
Old May 9, 2009 | 01:56 AM
69gto96z's Avatar
+1 for the crane 10308's
Texas_96_Z
Mar 2, 2007 11:44 PM
user 647483
May 18, 2006 07:13 PM
aarontracy
Mar 4, 2006 08:58 PM
BadCamaro
Jan 12, 2006 11:40 AM
formula69
Apr 1, 2005 12:55 PM
