cc503 cam with 1.6 or 1.7
Old Mar 21, 2007 | 11:04 AM
  #16
Z-RATED94's Avatar
Originally Posted by steve9899
There are plenty of people with 1.7 on stock and mild to moderate cams (up to about hotcam/503 territory). Hard to search for on this board since it won't take "1.7" as a search term.
A couple that I found right away:
http://camaross.com/forums/showthread.php?t=422491
http://web.camaross.com/forums/showp...19&postcount=4
http://www.camaross.com/forums/showthread.php?t=180122
You can also find plenty of people on other LT1 forums with 1.7s. Here's one I have bookmarked:
http://www.wku.edu/~nathan.plemons/h..._corvette.html
There have been a few people with 1.8s on stock cams, and none of them reported any serious geometry problems, either.
Lots of uninformed fearmongering here.
Gave it a quick read, and for various reasons as was stated in those threads I'm still not convinced that's the way to go for more lift. But if you think it's worth it, that's fine by me. I too thought about some 1.7s, but like I said, in this case, I'll go with the masses and the 1.6s. If I what more lift, the cam is where I'll look. More work, but I'd rather go with proven set-ups, than some thing that is more of a guess, as far as problems and in some cases, unknown expenses. Thanks for taking the time to post those links up though.
Old Mar 21, 2007 | 12:44 PM
  #17
buzz12586's Avatar
The main problem I see with going with a 1.7 rocker is that if you ever changed cams in the future to something bigger you would have to change back to 1.6 rockers.
Old Mar 21, 2007 | 04:59 PM
  #18
Dave1980's Avatar
Originally Posted by buzz12586
Hey Dave1980 do you have any dyno numbers or track times with your setup?? I'll be running almost the same exact setup.
Sorry man, I have absolutley no times or dyno #'s with this setup. I doubt I will, because I am going to be rebuilding soon, and have a exhaust leak at the moment. (stripped threads on #8 exhaust port.) (I am not going to pull heads till rebuild.)
I can say that the car has much more power after the cam went in. All of the supporting mods work together with this very streetable combo.
About the 1.7RR, dont they put way too much stress on your rocker studs or bolts? I believe that is why many steer clear of them.
Old Mar 22, 2007 | 01:11 PM
  #19
sbs's Avatar
sbs
Originally Posted by CamaroSS8887
Is there going to be much of a difference with them. The car is only driven during the summer and sees the track 3 or 4 times a year. I have stock heads and im getting 3.73 for gears.
Oddly enough, a thread started today on impalassforum on CC503 with 1.7:
http://impalassforum.com/noncgi/ulti...c;f=1;t=011913
Apparently user "Spartus" over there has this setup. You might PM him with your questions, to get information from someone with actual experience.
Old Mar 22, 2007 | 06:55 PM
  #20
lilronjohnson693's Avatar
thats me. i just talked to Lloyd and gave me his opinion and said thats not a good idea because of the XFI lobes and the way it opens the valve. I'm just gonna bite the bullet and get the LE1 cam
Old Mar 22, 2007 | 07:51 PM
  #21
PoorMan's Avatar
Look at sig. Love my set up.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
alliance12364
Mar 6, 2015 04:39 PM
