CC503 112 LSA vs. CC503 114 LSA
Old Nov 19, 2008 | 05:47 PM
Counted Out's Avatar
So I bought a used cam from a member on here, and after talking to Greg Rollins at CompCams, it turns out the cam I purchased was a custom ground cam with the same specs as the CC503, but with 114 LSA (the normal CC503 has a 112 LSA).
What will be the difference between the 112 LSA and the 114 LSA? Any noticeable HP differences, RPM differences, etc.
Thanks guys.
Old Nov 19, 2008 | 06:25 PM
<Puck>'s Avatar
On paper it will peak sooner, make more torque, idle smoother, pass emissions easier, respond better to boost and large doses of nitrous, be easier to tune, and make slightly less peak NA power.
In real life? Probably no noticable difference to the driver if you somehow switched out "on the fly".
I would not worry about it, just the fact that you chose the 503 means it is not an extreme or max effort build, so it is nothing to worry about.
Old Nov 19, 2008 | 06:31 PM
Not an extreme build by any means.
The tuning will be done by a a mailorder tuner, and it does need to pass emissions so it being easier to tune will be a good thing.
Old Nov 19, 2008 | 07:54 PM
seawolf06's Avatar
You wouldn't notice the difference.
Old Nov 19, 2008 | 09:47 PM
I bet you will.
The 114 LSA is going to idle noticeably smoother and seem tamer. I've seen plenty of 503 112 LSA idle videos and they all sound very choppy compared to the 503 114 LSA that I run in my daily driver.
Old Nov 19, 2008 | 09:49 PM
seawolf06's Avatar
I or you would, but I don't think he will.
Old Nov 19, 2008 | 09:53 PM
I guess I can't hear the difference in idles.
Old Nov 20, 2008 | 07:43 AM
seawolf06's Avatar
Didn't mean it like that, but have you ever heard one with a 112 LSA? Will you have two side by side so that you can compare?
What I'm saying is that if you have the cam already just use it. It might actually work better for what you need anyway.
Old Nov 20, 2008 | 05:57 PM
I've heard videos of the 112LSA, which is one of the reasons I wanted it. But from everything I've read there is a very notiable difference in idle - yet not much of a difference in power.
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 25, 2015 05:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
