View Poll Results: Which Cam?
CC306
15
38.46%
XE227
7.69%
XE230
19
48.72%
Other (please explain)
5.13%
Voters: 39. You may not vote on this poll
Cc306/xe227/xe230
Old Oct 9, 2003 | 03:02 PM
  #31
Brettinator's Avatar
all of those appear to be decent cams from various feedback. I like the GM847 thus far.
Old Oct 9, 2003 | 03:07 PM
  #32
chasmanz28's Avatar
Originally posted by NiteRider
Well said, very streetable, very torquey specialy with stock heads and the cam keeps it's TQ curve flat and fat! From 3500 rpm to about 4900 rpm i'm doing 343 to 344 rw tq. Power everywhere indeed!
niterider i noticed your running the 230/236 cam on stock heads, how did it effect your gas mileage, and would the stock lifters and pushrods hold up?
Old Oct 9, 2003 | 03:35 PM
  #33
HM Murdock's Avatar
I chose the 306 because of the extra exhaust lift and duation, our engines benefit from it. It's one of the main reasons I don't care for the hotcam, actually.
Old Oct 9, 2003 | 04:03 PM
  #34
NiteRider's Avatar
Obviously mileage got a little worse, but nothing that would make me complain, I am running 94-octane gas of course. As for lifters I’d say with a cam that has such a aggressive lobe pattern I’d change the lifters, pushrods I bought new stock hardened ones just because everything else in the valvtrain was being changed. This winter those stock heads are coming off.
Old Oct 9, 2003 | 04:52 PM
  #35
TreySpeed's Avatar
On permanent vacation
stock heads and stock bottom end, there is no reason to run anything above 91. even less so with a bigger cam. some places only have 92 and 93 available so you dont have a choice-
but i've never heard of anywhere only offering 94.
Old Oct 9, 2003 | 06:09 PM
  #36
madhatter's Avatar
MI does. I miss it
I believe the owners manual actually says 92 is the recomended. All that is in AZ is 91 at the pump though. unless you want 100 or 106 :P
Old Oct 9, 2003 | 06:33 PM
  #37
Kain's Avatar
Re: Cc306/xe227/xe230
Originally posted by MaddHatter
I'm looking for a 11sec N/A daily driven sleeper... LT4 Heads ported, JH LT's, 3.73s, stall, Musser CAI, and a few other misc mods will also be going in. I don't mind lope, I actually like it as long as it's nothing hardcore. I also love Torque over HP... I'm looking to pull 1.3-1.5 60's with enough time behind the wheel.
I think the 306 is a little too much cam for the stock bottom end, so the XE230 got my vote. I was originally going to go with the XE230 but with a 111 lobe. The order got messed up so I got the 306 from Thunder Racing.
Neither of those cams would be a sleeper, even a 114 you can tell its cammed. If you want a sleeper, 116 or 117 lobe seperation would idle like stock.
Also, you won't be able to pull 1.3-1.5 60's. Maybe a 1.59 if your really lucky.
But a 11 second car is possible with an auto. With stock heads and a cam I ran 12.2's spinning slightly to 1.65-1.68 60's. With ported stock heads, you'll hit high 11's no problem.
Old Oct 10, 2003 | 08:29 AM
  #38
MaddHatter's Avatar
Re: Re: Cc306/xe227/xe230
Tell JC and MikeV6 that... they pull .5xx R/Ts and low 1.x 60's... I'll see if I can't find a vid of Mike chopping the tree.
I don't see 1.3s-1.5s being a problem on slicks with a stall converter and 3.73s pulling the kinda torque I want.
Old Oct 10, 2003 | 09:23 AM
  #39
xxsaint69x's Avatar
just get it over with and get a CC306
Old Oct 10, 2003 | 09:26 AM
  #40
MaddHatter's Avatar
[bobby]Momma Says...[/bobby] "Paitence is a virtue"
Old Oct 10, 2003 | 10:34 AM
  #41
FacelessZ's Avatar
XE 230/236 is just about the same as the CC 306 but it has a little less on the exhaust side...and it's a bit more streetable...
XE 230/236
Old Oct 10, 2003 | 11:09 AM
  #42
RealQuick's Avatar
Just dynoed mine with an old tune from last year. Anyone wanna help me post the graph?
Old Oct 10, 2003 | 11:13 AM
  #43
MaddHatter's Avatar
Email it to me at austin@macrecruiters.com
Old Oct 10, 2003 | 11:26 AM
  #44
rje's Avatar
rje
I have a 228/236 Bullet cam and have run the times in the sig.
MaddHatter, you must not do a whole lot of drag racing, because if you did you would know that there is no way you're going to see a 1.3-1.4 60ft in a heavyass camaro with only 3.73 gears and 350 cid no matter what cam you put in it. Now if you put some 4.11's, slicks, and about a 200 shot you may get in the 1.3's.
Randy
Old Oct 10, 2003 | 11:44 AM
  #45
MaddHatter's Avatar
Randy
I was thinking 3.73s, 2800-3200 stall, Slicks/Skinnies but we'll see.
