CC306 Track results!
Old Jun 10, 2003 | 11:44 PM
97Whitez28's Avatar
Well, I wasn't really gonna go to the track tonight, but I was really getting the itch, so with the weather being somewhat cool. I deceided to go for it....
I had 6 runs in total with the first being the worst and the last being the best, here is the break down of times....remember before I did anything to the car it was running 13.9-14.0@ 100-101MPH..
14.4@76...Let off at 1/8 mile just to see where I was
13.365 @108.0
13.017 @108.84
13.057 @107.63
13.026 @108.45
And the full breakdown for the last run..
This was with a 6000-6200 RPM clutch drop to get the car moving.... Let me tell ya it took some ***** for me to do this on a stock 10 bolt rear end!
R/T: .427
60': 2.090
330: 5.577
1/8: 8.447
MPH: 85.41
1000: 10.921
1/4: 12.997
MPH: 108.66
Well I finally did it and probably won't be hitting the track again until the rear end and gears go in before next summer....That is unless someone has 2G's sitting around that the are willing to part with to satisfy my need for speed....
This is with CC306 Cam, MAC Headers, 3 Angle Valve Job, Custom Tuning, and 315/35ZR17 Kumho Victoracers out back......
With the Stock Clutch, 10-Bolt, Bottom End
Old Jun 10, 2003 | 11:49 PM
94 CAMRO Z28's Avatar
Re: CC306 Track results!
Old Jun 10, 2003 | 11:50 PM
FastZinTennessee's Avatar
Are you running an LT4 knock module??
John
Old Jun 10, 2003 | 11:52 PM
madwolf's Avatar
Those numbers seem low to me. xxsaint69x traps 115s with a cc306 and stock heads....
Old Jun 10, 2003 | 11:58 PM
97Whitez28's Avatar
Haven't picked up the KM yet, but on autotap there is very very very little knock retard......less than 1* I am told....
Does XXSaint69X have a different set of gears? Cause let me tell you I can't launch this thing with out running her up real high as evident with my last launch....I think it has more in it, having some clutch issues also....
XXSaint69X ---- Did you Dyno your car? What kind of power are you making, and what gears do you have?
Old Jun 11, 2003 | 12:01 AM
ibanez6rg's Avatar
xxsaint69x has 4.10s and Hooker Lt's
Old Jun 11, 2003 | 12:03 AM
97Whitez28's Avatar
That may explain part of it.......
madwolf's Avatar
Still though. He should at least be seeing some 112s....
Are you running on the OBDII computer? Who did your tuning if you don't mind me asking?
Old Jun 11, 2003 | 12:05 AM
Smokn '94 Z's Avatar
Question
Did you got to 66 tonight? The weather is not good for racing today.... The DA right now is 2215!!! I think in even decent air you will see much better times or at least MPH...
Old Jun 11, 2003 | 12:10 AM
97Whitez28's Avatar
Yeah I was 66.....Very dead today (Surprise Surprise) only reason I actually ran the car.......
BV Performance Tuned it...Road Tune then Dyno Tuned......A/F as flat as a board....
Old Jun 11, 2003 | 12:12 AM
What does BV (Brian) charge? I met him once at FLP & he seemed petty cool.
Old Jun 11, 2003 | 12:16 AM
97Whitez28's Avatar
It was $400.....Yeah he is a pretty cool guy....I would have to recommend him....
Hey Smokn' Check out Http://www.fbodyowners.com bunch of local guys, we get together all the time.....
Old Jun 11, 2003 | 12:34 AM
madwolf's Avatar
Sounds like tuning isn't your issue then. What kind of exhaust do you have?
Old Jun 11, 2003 | 12:45 AM
97Whitez28's Avatar
MAC Headers, Off-Road Y-Pipe and some cat-back from Tuffy that actually flows really good.....
If I wasn't afraid of blowing up the rear-end I would try going again next week, to see if it was the bad weather conditions, but I can't afford to lose the rear-end
Old Jun 11, 2003 | 12:47 AM
madwolf's Avatar
Yea man... 6K rpm dumps on the stock rear-end.... I wouldn't do it again if I were you... Was that with the Kumhos?
