cc306, stock heads, what rpm?
Re: cc306, stock heads, what rpm?
I had red line set at 6800 and was shifting between 6500-6800. Our stock tachs suck. Now I will have a shift light at least to help. I can check it with the pcm to see where I am actually shifting.
Landed me two spun rod bearings.
Well before I spun 2 rod bearings and a main bearing I was shifting at around 6500 with mine.......
I don't think these motors particularly like being spun that fast but o'well time to build the motor in the sig......
these guys are right, stock haeds are going to quit "breathing" way before 65-6800 anyways. i would say drive it and do what feels right. the engine will tell you where it wants to be shifted if you just "feel" it. i know the wording dont make sense but i think most of you know what i mean,
I got a dyno graph send me ur email. Quits making power at 6200 so if I'm runing hard I shift at 6400 to fall back into power band. If your setting a limiter I would set it at 6600, that should be fine, and wont hurt if you bounce off it.
Originally Posted by 96flame
Cutout open and closed shown
what other mods do you have. mine is bolt on only and i was expecting a little more than that. gunthers car was a cam and header car and he was putting down 399rwtq i dont remember the rwhp.
