CC306 & stock heads
Old Jan 7, 2006 | 12:07 AM
LALT1's Avatar
CC306 & stock heads
Guys I am wondering if anyone is runnign a CC306 on stock heads, well with springs replaced of course? Mods will be long tubes, headers, TB, injectors, and the 306. I dont think the budget will aloow for a set of heads right now so i was wondering if anyone is running this set up? Any feedback from anyone runnign it will be greatly appreciated. Any dyno #'s will be great.
Old Jan 7, 2006 | 12:48 AM
future lt4 383's Avatar
Re: CC306 & stock heads
i got cc306,stock heads,30lbs accel injectors,intake,headers. put down 340 or something. it was a really crappy clutch so it could of been more. but i ran 12.5 at the track. with stock 10bolt
Old Jan 7, 2006 | 12:49 AM
109mph
Old Jan 7, 2006 | 01:01 AM
Bersaglieri's Avatar
Red96z ran 12.3 @ 110 his first and only time out with a bolt on Auto.
XXSaint69X ran the same, only I think his trap was 114-115.
Either way its a strong proven camshaft, just needs to rev a bit higher than most.
-Dustin-
Old Jan 7, 2006 | 01:02 AM
Sleeper_Z's Avatar
Im running a CC306 with stock heads, intake, injectors and t-body. So far my best pass has been a 12.7@111.9 with a 2.00 60ft. Im really hurting on the launch though. My 3.23s with a 2.66 first gear T56 is horrable off the line. But I run door to door with my friends car who runs 12.4s@109-110 from a 40mph roll which he also running the CC306 with stock heads, intake, injectors and t-body but he has an auto with a 3200 vig converter and 3.73s. With a good 60ft and a few more bolt ons and suspention parts I think his car could go 12.0s without a problem. Just make sure you set your rev limiter for 6500rpm at the most because even with stock heads the CC306 likes to rev, well as long as you have good valve springs
Jeremy
Old Jan 7, 2006 | 08:44 AM
LALT1's Avatar
Thanks for the replies guys.
Old Jan 7, 2006 | 09:15 AM
MyShibbyZ28's Avatar
Jeremy
Not worried about the crank? Can the stock crank handle 6500 with no problems?
Old Jan 7, 2006 | 09:48 AM
Sleeper_Z's Avatar
Ive been spinning mine to 6500 for almost 2 years now with no problems. I actually have my rev limiter at 6700rpm and Ive hit it more than a few times.
Jeremy
Old Jan 7, 2006 | 12:07 PM
jsetzer's Avatar
12.80 @ 109.8 2.0 60ft street tires stock heads. Dyno'd 335/350
Old Jan 7, 2006 | 01:25 PM
Lots of people seeing well over 6500 with the stock crank. Although at that level my worry is oil pressure.
-Dustin-
Old Jan 7, 2006 | 08:01 PM
96flame's Avatar
Thats what I'm running through cats but needs more tuning up top
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
