cc306 owners come inside. need info...
Old Nov 29, 2006 | 03:26 PM
  #16
93yellowta's Avatar
crack..
Originally Posted by Severous01
check all your vacuum fittings, hoses, connectors, and all the electronics/hardware that connects to them. i had a hairline crack in one of my lines. still have some reverse/first issues and some issues when i come to a halt, but my surging is gone in the rpm ranges you speak of
do you know which line it was that was cracked. Im going to probably replace all of my vacuum lines this winter...
Old Nov 29, 2006 | 06:41 PM
  #17
Severous01's Avatar
one to the egr. it had actually fallen off the clip, came in contact with the header and the hot/cold action got to it i guess.
Old Nov 29, 2006 | 06:45 PM
  #18
93yellowta's Avatar
egr...
oh okay.. I did away with the egr.. put on the blockoff plates.. so I'll check over all the other lines... one more thing, my map gasket is really worn out, fits very loose on the tube, could that cause a leak?
Old Nov 29, 2006 | 07:55 PM
  #19
mdacton's Avatar
my map o-ring is worn too...I can't find one anywhere
Old Nov 29, 2006 | 09:41 PM
  #20
Sweetred95ta's Avatar
93yellowta, if you're worried about an intake leak, take some starting fluid (Ether) and spray it around the intake and hoses. The car will rev if it sucks the Ether in by means of a leak.
Old Nov 29, 2006 | 10:39 PM
  #21
93yellowta's Avatar
thanks..
thanks sweetred...I'll get a can and check it out. because it takes 3-5 secs. for the car to rev. down...
Formula Steve
Sep 19, 2023 08:31 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
