cc306 orcc503
Old Mar 20, 2007 | 09:19 PM
93v8clone's Avatar
cc306 orcc503
i know im gonna open a whole world of crap for this but what would be better for a cam in my car new ported aluminum heads ported intake longtubes 1.6 rr's and a 2800 stall with 3.23;s gears the cc306 or the cc503 mostly a weekend car with street use and strip
Old Mar 20, 2007 | 09:32 PM
sn8ke eatr's Avatar
you could get away with either, depends how radical you want it. id personally suggest the 503, since u have a rather small stall. u might want to upgrade to a 3500 or so, do the 306 and some 3.73s then youd be flying
Old Mar 20, 2007 | 09:39 PM
93v8clone's Avatar
i may go with a bigger gear butt i may go diff rearend before hand as the 10 bolt blows i also have 1 free stall adjustment if i need it also.....i know the lope dont matter but i kinda want one and i like the 306 whats the 503 sound like any clips or anything...if there is im all over it like a bum on a bologna sanwich
Old Mar 20, 2007 | 09:56 PM
matLT1's Avatar
I have the 503 and it has a very nice idle. Going to a bigger cam isn't always the best idea. You may get a little more peak power by using the 306, but you will need to rev the engine very high to ever see it. I would put a lot of thought into how you will be driving the car and what you want out of it before selecting a cam.
Old Mar 20, 2007 | 10:02 PM
Z95m6's Avatar
Thats a very good post. I originally started out with a large cam and am now down to a cam that has 20 degrees less total duration than my first cam. I thought peak numbers matter and so I went bigger, but never liked to rev my car high enough to make the power. I know have a smaller custom cam that kicks hard in the low-midrange right where I drive. Lately it looks like it would be hard not to go with an LE1 cam. People have been putting down 380-400rwhp and they don't have to rev real high to do it either.
Old Mar 22, 2007 | 06:09 PM
93v8clone's Avatar
how is the 503 on spray im gonna do a 150 shot prolly or 200 not sure yetsee what the motor likes
Old Mar 22, 2007 | 08:40 PM
jay_lt4's Avatar
503 works very good with spray, im running 10's with a 383 and 503 cam and 150 shot
Old Mar 22, 2007 | 10:51 PM
Critter's Avatar
unless you are willing to spin the cc306 up to 6500+ and have headers you will be wasting your time with it. and when you start spinning that high you have to worry about your rotating assembly.
Old Mar 23, 2007 | 01:20 PM
stereomandan's Avatar
Like Critter said, you need to REV the CC306 to get the power. The CC503 is a much better choice.
Dan
Old Mar 23, 2007 | 05:54 PM
93v8clone's Avatar
cool dont wanna spool it up to 6500 all the time what stall should that be at with the 503
Old Mar 23, 2007 | 06:54 PM
Heatmaker's Avatar
Advanced Member
you know, the cc503 and CC306 aren't the only cams out there.... just the most talked about. Sounds like your looking for a mild cam there are allot of variations out there that you should search around and look at first.
Old Mar 23, 2007 | 08:57 PM
93v8clone's Avatar
i know not the only cams out there but they have worked the best for me in the past had 2 lunati blow lobes off and 1 crane snap i just like the power ranges of both and witch one will like the spray better.....oh yeah and i like the lope of the 306 i know lope dont mean anything and if that was all it was about id do a hotcam but id like suttin up top with a lope
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
