cc306/ optispark
Old Jan 31, 2004 | 09:30 AM
lt1g3n's Avatar
cc306/ optispark
Would i be ok using the 95-97 optispark, or do i have to get the 93-94 optispark ? Just not sure what the pin length is for the 306 , but im assuming i will have to get the newer one, not positive tho, any one ?
(right now i don't have any optispark, so it doesn't matter which one it is )
Thanks.
Old Jan 31, 2004 | 04:54 PM
$hawn's Avatar
Nobody can give you any opinions or suggestions untill we know what year your car is.
Old Jan 31, 2004 | 05:06 PM
lt1g3n's Avatar
1983 camaro, but that doesnt help you, this motor i dont know the year of but it was had cast iron heads , so it's a impala or roadmaster block, its new no miles but i dont know where it came from :O , i thought the only thing that mattered was to know the length of the pin on the cam and the hole dont mind me
Old Feb 1, 2004 | 09:26 AM
96capricemgr's Avatar
All b/d-body(which included Caprice and Fleetwood too) LT1s(iron heads) got the later vented opti. Pin length I think you want about .625", if you want to double check that I am sure a search here will turn up lots of info. I know the earlier stuff was shorter but the .625 is supposed to work across the board. If you have the old stock cam from the motor just check it against that, and do not force the opti on.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
