cc306 instal bout to start..this is what i have so far..what else do i need...
Old Jan 5, 2006 | 03:41 PM
TransAm396's Avatar
Ok i got:
cc306
comp 918(beehives)
10*locks
10* retainers
locators
7/16 ProMag 1.6 NSA
7/16 studs
front gaskets
intake gaskets
guideplates
hardend pushrods
new plugs/wires
...thats what i have SO far...i will be getting long tubes soon so i know i need those along with the tune. Any other suggestions on things that im going to need to get this going?
Old Jan 5, 2006 | 04:35 PM
kirschman's Avatar
Re: cc306 instal bout to start..this is what i have so far..what else do i need...
If it was me I would go ahead, if its still apart, and convert it over to electric w/p so you can run a true double roller timing chain. Even if its a low mileage car i would put a (cloyes) t/c in it. Free's up a few more horses and ya dont have to worry bout the pump on the opti.
Old Jan 5, 2006 | 05:20 PM
zx1216's Avatar
yea, your goin to need a new timing set of some sort, i would also agree to go with the electric wp and double roller set up
Old Jan 5, 2006 | 05:29 PM
jsetzer's Avatar
If you plan to spin much past 6k do not use another stock one. I have @ 2 oil changes on my cc306 setup with new oem timing chain / gears and there was more slack than you could shake a stick at. Can't belive it didnt break.
Oh ya, was spinning to 6500 sorta often and a couple of 6800 rev limiter bounces on the dyno.
Old Jan 5, 2006 | 05:53 PM
TransAm396's Avatar
damn...i beat the hell out of my cars(thats why i change the oil ever 2-2300miles. Ive never heard of hat happening. I was told I would be fine using my chain. Anyone else have the same problem?
Old Jan 5, 2006 | 05:57 PM
396D1SS's Avatar
my stock chain has lasted 2 years of 400 plus rwhp and a bunch of 7200rpm pulls and still works fine
Old Jan 7, 2006 | 08:33 PM
Wckd94Z's Avatar
I did the cloyes double roller/electric wp. I don't see why anyone wouldn't do it just for peace of mind. Also think about the accuracy of your cam and ignition timing...
Old Jan 7, 2006 | 08:47 PM
SLeePer350's Avatar
stock chain is fine...converted to electric w/p around 70,000 miles. currently running about 360 to the wheels and spin to 6.4k ever now and again. brand new chain was just as loose as "worn out" stock chain. take it for what its worth...if you are trying to save money, then skip it.
Old Jan 8, 2006 | 02:31 AM
Sleeper_Z's Avatar
I installed a stock replacement chain while doing my cam swap and it had WAY too much slack for me (you could actually turn the cam gear a few degrees and had about a half inch of slack on one side if you held the other side tight) so I converted to vented opti and went with the cloyes true roller. It was a night and day difference between the two. The cloyes is nice and tight and Ive done quite a few cam installs since and I wont put another stock replacement chain in after seeing the difference between the two.
Jeremy
Old Jan 8, 2006 | 04:02 AM
TransAm396's Avatar
damn...i dunno what to do. do i wait a few more weeks b4 doin this **** and save up.....i dunnnnno.
Old Jan 8, 2006 | 04:04 AM
Sleeper_Z's Avatar
If your gonna do it you might as well do it right. Thats just my oppionion though.
Jeremy
Old Jan 8, 2006 | 08:04 AM
belac350's Avatar
I would look at motor mounts and a clutch. The CC306 is more than the stck can handle.
Old Jan 8, 2006 | 09:07 AM
TransAm396's Avatar
yeah clutch is a given....along with long tubes an a tune. I just have to find a stock exhaust now. (i sold my magnaflow) i def. want a stock exhaust to keep this thing quiet with a cutout closed.
Old Jan 8, 2006 | 05:18 PM
belac350's Avatar
I just did CC306 cam. All together its about the max I would deal with on a daily driver. The clutch is tough sometimes (Spec stage 3). I pulls very hard over 3K.
Old Jan 8, 2006 | 08:33 PM
TransAm396's Avatar
everyone says it pulls hard past 3k
