Cc306 Hmmmmmm
Old Jul 19, 2004 | 05:03 AM
bo3abd's Avatar
Cc306 Hmmmmmm
well .. i placed the cam in its place... and made sure its all the way in .. then when i put the timechain and try to place the cover in place .. noticed that the metal nipple thingy coming out of the cam top is hitting the cover
.. is that normal ?... well what i did was cut that nipple down to the same old stock cam nipple length and installed the cover fine .. did you guys face the same thing with your comp cam 306 ??????????????????
Old Jul 19, 2004 | 07:35 AM
F(ast)-body's Avatar
Re: Cc306 Hmmmmmm
yeah that's normal....I tapped mine in til it was the proper length with a ballpeen hammer...
Old Jul 19, 2004 | 08:52 AM
MYT30TH's Avatar
Re: Cc306 Hmmmmmm
When I installed mine it actually was to far in and had to pull it out alittle
Old Jul 19, 2004 | 09:15 AM
Re: Cc306 Hmmmmmm
yeah I've heard of that too....just make sure that whenever you are installing a new cam in an LT1 you measure the dowel pin (metal thingy sticking out of the cam) to make sure it's the same length as the old cam. I learned the hard way the first time and ended up destroying a brand new opti because I left the pin out too long.....
Old Jul 19, 2004 | 12:37 PM
TN94Z's Avatar
Re: Cc306 Hmmmmmm
I used a dremel and cut it down to the proper length. It took it right off...I got mine from Comp, it was way too long...
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
