cc306 cam questions
Old Nov 25, 2004 | 08:34 PM
94formulabird's Avatar
cc306 cam questions
Ok so I was thinking of getting a cc306 cam. A buddy has one hes willing to sell to me. If I have the cc306 cam, machined comp springs and retainers, 1.6rr's and new gaskets, I am set right. I have done some research and I have read that you may need machine work done to the heads because its a big cam. Is this true? Remeber, this is the internet and everyone is a mechanic and has a 10 sec car. How big is it really, I need it to be streetable. Who has had this cam before, and what did you think? By the way, I have a 94 formula a4 with intake, exhaust, cutout, airfoil, and shiftkit.
Old Nov 25, 2004 | 09:11 PM
chrism400's Avatar
Re: cc306 cam questions
Not to be snotty but why don't you ask your buddy who sold you the cam these questions?
Old Nov 25, 2004 | 10:59 PM
dmoor88's Avatar
I know of people who have tossed in a cam like this with only changing the gaskets and springs, nothing else.
You'd probably want some Comp R lifters if you plan on running RPM's above ~6200 and a replacement timing chain; something a bit more heavy duty. Id also replace the timing sprocket and, if at all possible, pick up some 7/16" studs for your rockers (if they'd fit)
Old Nov 26, 2004 | 03:11 AM
cmking26's Avatar
The cam won't make all its power without p&p heads IMO. It will also need a tune, some guys have run it without but I would spend the $$$ and get one. As far as streetable I think mine is great. The cam makes power up high and pulls till about 6800 or more. So if your not willing to rev your motor that high it might not be the right cam for you. I run mine up to 6500rpm and it pulls hard, I've only once hit 6800. I love it and consider mine very streetable.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
