cc306 ???
Old May 12, 2004 | 10:52 PM
1984camaroz28's Avatar
cc306 ???
is this cam gona be enought for this 383 setup
11 to 1
trick flow heads
Old May 13, 2004 | 12:01 AM
KCFormula's Avatar
I don't know the flow numbers on the T.F. heads but the CC306 makes good power in heads where the exhaust flow isn't all that good. To me any non-stock head motor should not use an off-the-shelf cam. If you have the flow numbers on the heads you are using call up comp cam or some other cam manufacturer and get a custom made cam that matches your heads. That way it will make more power, be easier to tune and drive better on the street.
However, a simple answer to your question is yes. Yes it will run alright with that cam but it won't be the "optimal" choice.
Old May 13, 2004 | 12:07 AM
badblackta's Avatar
my buddy is running a variation of the cc306, but it is on a 111 lsa, in his 383, and it scoots along pretty good
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
