CC306 on a 114 LSA?
Old Feb 23, 2008 | 11:56 AM
LSWHO's Avatar
CC306 on a 114 LSA?
What would change in power? Would I be right to think that it wouldn't need to be revved as high and would be a little torquier?
...they do come normally ground on a 112 correct?
Also if I am right, which I doubt I am, but if I am where could I get one ground like this?
Old Feb 23, 2008 | 12:20 PM
96capricemgr's Avatar
When people talk about widening the LSA and the effect it has on power and powerband they usually neglect to consider that all the off the shelf stuff is alread spread extremely far from optimal.
Going wider just screws it up even more.
They also want to try and make stuff into "nitrous grinds" for baby 150 shots and the like when a "nitrous" cam should rarely be considered at nywhere near that low a level.
Old Feb 24, 2008 | 10:40 PM
rskrause's Avatar
Moderator
Generally speaking, wider lsa will increase the rpm for max power. But that is only a gross generalization and it depends where you started. With that particular cam, it probalby would make very little difference. Comp would be glad to grind it, but I get the feeling you shouldn't be designing your own cam, no offense.
Rich
Old Feb 25, 2008 | 07:48 AM
LSWHO's Avatar
oh I know I shouldn't
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 25, 2015 05:47 PM
