CC305 w/ hotcam springs and 1.6's
Old Jul 3, 2005 | 10:01 PM
Zenger419's Avatar
will I be ok running this cam with the hotcam stuff?
what is the lift w/1.6's ? I know the dur is 220/230
Old Jul 3, 2005 | 10:02 PM
Bersaglieri's Avatar
Re: CC305 w/ hotcam springs and 1.6's
No, the lift on the CC305 is too great for LT4 springs. Biggest you can go is the Hotcam.
-Dustin-
Old Jul 3, 2005 | 10:05 PM
FastZinTennessee's Avatar
Yea if the lift is above .525 then you'll need to upgrade springs.
Old Jul 3, 2005 | 10:09 PM
Lonnie Pavtis's Avatar
Lift is .544" with 1.6's
Springs may be OK unless you plan on high rpm. Check your closed pressure to be sure it is high enough. I do not currently have a cam card to see the recommended spring pressure, but I shoot for 130 on the seat with that cam.
The correct spring is a 986.
Old Jul 3, 2005 | 11:19 PM
69vette's Avatar
do not run it with hotcam springs!!!
Old Jul 6, 2005 | 07:48 PM
Revis_Racing's Avatar
Do not use Hotcam springs.
Use 986 Dual Springs or 941-16 springs.
941's (single w/ damper) are alot stiffer than 986's, but 941's will fit in the stock pockets without changing seals. You will need to use CC shims and remove the stock seats but they will work.
941 specs
135#@1.75"
359#@1.25"
rate = 447#/in
Bind@1.130 equals about .600" lift
HarleyZ28
Oct 5, 2015 06:23 AM
tnorm077
May 23, 2015 09:10 PM
k1996z28
Apr 13, 2015 06:54 PM
Red_94Formula
Jan 22, 2015 12:17 AM
