cc305 vs. cc306
cc305 vs. cc306
I currently have this setup...
355ci
-balanced rotating assembly
-ross forged pistons
-eagle Ibeam rods
-ARP main studs+head bolts
-cc305 cam
-stock heads port match comp ratio 11to1
-cloyes double roller timing chain
-cc1.6 RR,pushrods,springs,rocker studs
-mezeire HD electric water pump
-hooker LT coated headers
-clevitte H-series bearings
-taylor 10mm wires
-ngk tr55 plugs
This is all going through a stock M6 with Spec III clutch and 4.10 Richmond gears in the back (stock drive shaft).
I assume I'm pushing around anywhere from 350-400rwhp.
If I go from a cc305 to a cc306, how much of a gain will I be looking at without a tune? How much of a gain with a tune?
355ci
-eagle Ibeam rods
-cc305 cam
-taylor 10mm wires
-ngk tr55 plugs
Re: cc305 vs. cc306
You will see more of a gain with a tune either way. From what I understand, the cc305 cam is more of an Auto Tranny Cam. The cc306 was designed for the Manual Tranny. You will give up a little driveability with the cc306, but you need a tune. If you install the 306 cam without a tune, you will have a little trouble. It will have an unsteady idle, and cam surge at low RPMs will be a pretty noticable. I have a great tune, and I still have some surge, and after about a month, the computer is still trying to figure out the idle we set. Either way, a tune is a definite necessity.
Hope this helps,
BIZ
Hope this helps,
BIZ
Re: cc305 vs. cc306
Sounds like you could benefit from a dyno tune from The Milkman
Re: cc305 vs. cc306
Originally Posted by Kurt Crosbie
how about a GM 847?
NewsBot
Jul 3, 2015 02:10 PM
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
