cc305 peak hp?
Old Aug 22, 2005 | 11:29 AM
Black6spdZ's Avatar
cc305 peak hp?
I have a full bolt on 96 m6 with this cam and peak hp was b/w 5700 and 5800, (335rwhp)this seems a little low to me. The heads also have a decent port job. The car will rev higher but seems to miss, or float the valves. The opti and coil have been replaced and i checked adjustment of the rr seemed ok. Could it be the control module? Or is my car ok and i am just wishing that it pulled harder up top? If i narrow it down to springs then i am going to live with it because i am going LE3 this winter
Old Sep 1, 2005 | 11:54 PM
redcamaroz28's Avatar
Re: cc305 peak hp?
I have this exact same problem w/ my XE230/236. It misses right at 57-5800rpms. Sometimes it will rev past and not miss, but most of the time it misses consistently at those rpms. I have 30/lb injectors and the fuel pressure does not drop when it surges. BTW, I am running the CC612 springs, so could I be getting float from these?
Black6spdZ: What springs are you running?
Old Sep 2, 2005 | 01:28 AM
Z95m6's Avatar
Re: cc305 peak hp?
I'd say you have valve float. Bret Bauer told me even my old 987's probably weren't holding the aggressive lobes of my old 230/236. I haven't looked to much into those 612's but i know they are single spring and my 987's were dual springs. So i'd think you probably don't have enough spring.
Old Sep 2, 2005 | 01:56 AM
ss#1230's Avatar
Re: cc305 peak hp?
sounds like someone needs a hydra-rev kit....
Old Sep 2, 2005 | 03:37 PM
Re: cc305 peak hp?
Thanks guys, I was afraid it was valve float. I'm gonna go with the 918's then. And to think I was finally gonna get a new clutch, too. Oh well, I've got to get my car dyno ready in a week for a dyno day (money goes towards hurricane victims, etc.).
Ryan
Russ95Z28
Apr 23, 2015 01:55 PM
langtown77
Dec 20, 2002 11:27 PM
12secondv6
V6 Tech
Oct 25, 2002 02:59 PM
Timberwolf
Advanced Tech
Aug 5, 2002 10:35 PM
