cc305 with hotcam springs?
Old Aug 6, 2003 | 09:17 AM
VINCELEE123's Avatar
will this be ok? im gonna use 1.5 rockers and shift points will be @6400 rpms
would the extra lift from 1.6s be worth it?(ported heads peaking around .550")
ive got some 600" crane dual springs, but i was wondering which would be better
Old Aug 6, 2003 | 09:40 AM
sssalah's Avatar
The cc305 has 0.510" lift, so it should be ok with the hotcam springs that are used with 0.525" lift. If you plan on going with 1.6 then the change to the higher lift spring becomes a requirment.
Old Aug 6, 2003 | 09:54 AM
95TA8280's Avatar
hotcam springs suck. You might be "OK" with them, but with ported heads I think you should definatly upgrade...Also, why are you going with 1.5 RRS instead of 1.6??
Old Aug 6, 2003 | 10:16 AM
Dave Feerst's Avatar
why do hotcam springs suck? they are one of the lightest spring / retainer sets out there.
HarleyZ28
Oct 5, 2015 06:23 AM
Catmaigne
Jul 14, 2015 05:17 PM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
