cc305 and emissions
Old Mar 18, 2003 | 08:22 PM
Got-LT1's Avatar
cc305 and emissions
I want to get a cc305 ground on a 112lsa and mabye a few degrees more duration. If I got a custom tune from PCMFORLESS that was ment only for a smog test, do you think I will pass NJ smog tests?
Old Mar 18, 2003 | 10:37 PM
Wild1's Avatar
Yes, you should be able to pass. Email Bryan at PCMforLess. He is pretty good about emails. What you want to watch is overlap. By cutting back on the LSA you will be increasing overlap which could bleed HCs into your exhaust... possible fail. However, with a good tune on that mild cam you should be fine.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Russ95Z28
Apr 23, 2015 01:55 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
smackkk
West South Central
Aug 10, 2002 07:24 PM
