cc305 and cc503 ?
Old Apr 6, 2003 | 03:39 PM
PredatorZ28's Avatar
cc305 and cc503 ?
whats the differance? will either pass smog in cali? and what is the hotcam a 212/218?thanks
Old Apr 6, 2003 | 04:55 PM
Dr.Mudge's Avatar
Hotcam is a 218/228. The cc503 is an XE grind.
305 or Hotcam pass with proper tuning, maybe even without, as for the XE I dont know, its small enough there is a good chance, some claim the XEs are dirtier though.
Old Apr 6, 2003 | 05:15 PM
turbo_Z's Avatar
CC305 at .050" is 220/230 lift of .510/.510
CC503(XE 224/230) at .050" is 224/230 .503/.510
now when you buy a cc305 its usually ground on a 114 LSA whereas the XE is on a 112 LSA. what make a cam "dirty" however is the overlap since it forces unburnt fuel into the exhaust system. the more overlap you have.. the harder it should be to pass emissions. doing a little figuring, you get a total of 55 degrees overlap with the cc305 compared to the XE of 54.5 degrees on a 112. given that.. the XE should actually be a "cleaner" cam than the cc305 but it would hardly be noticed unless you get the cc305 ground on a 112 like many ppl do which will increase overlap to 59 degrees.
Old Apr 14, 2003 | 03:38 PM
which produces more power?thanks for the help i do not know much about the little differentes in cams
Old Apr 21, 2003 | 04:01 PM
TTT
97SSdude
Aug 21, 2015 09:36 AM
alphaauto
Jul 26, 2015 04:40 PM
Russ95Z28
Apr 23, 2015 01:55 PM
langtown77
Dec 20, 2002 11:27 PM
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
