Cc305
Old Feb 23, 2004 | 01:20 PM
z28poweredlt1's Avatar
Cc305
jsut wondering is a cc305 with 1.6 crane gold rr's fair for street use? and how do they work with stock heads and the xe612 springs? also will the computer stawrt freaking out? thanks in advance
-Mark
Old Feb 23, 2004 | 01:21 PM
i would really like to go as big as i can without screwing with the comp, and if i do have to mess with the comp how hard is it?
Old Feb 23, 2004 | 01:25 PM
AxeGrinder30thZ's Avatar
The CC 305 can be used on the street, as a lot of the guys on here have the 305 cam in their daily drivers. I don't know about your comp "freaking out" or whatever, but it would be best interest to have it tuned for the cam.
Old Feb 23, 2004 | 01:27 PM
Red96Lt1's Avatar
I would say port your heads too.
Old Feb 23, 2004 | 01:34 PM
I agree. Just depends on the owner of the car I guess.
I read in your sig that you are stock. You'll really want some headers before you drop in a cam, IMO. Don't choke your car by having a good cam w/ those crappy manifolds. Do some exhaust work as well.
Old Feb 23, 2004 | 01:36 PM
n20ta2's Avatar
I have that cam and its daily driver safe,If you want to get the most out of it however you need to tune the pcm.Its easy send it to www. pcmforless.com or another tuner and send all your specs along with it they send it back to you in a few days tuned,or have them send you a tuned pcm and send them yours as a core.Super easy and then you have no down time.
Old Feb 23, 2004 | 01:59 PM
With hooker lt's, and a free flow cat, and that cam with maybe mild porting what kind of performance do you think i might see? maybe above 330 rwhp? and the dyno tune of course, and what about without porting of the heads?
Old Feb 23, 2004 | 02:01 PM
Red96Lt1's Avatar
Deffiantly, you can get those #'s with the hot cam.
Old Feb 23, 2004 | 02:07 PM
wanna try the best i can to get into the high 12's without spending too much, and once i get a loan then the car goes 10's on an m6 NA!
Old Feb 23, 2004 | 05:20 PM
who makes that cam and where is the best place to buy it from?
Old Feb 23, 2004 | 05:44 PM
Seal's Avatar
cc305 is a bit more agreesive then the lt4 hotcam, so ur heads will be fine with it.... and its all for street use... (i dunno bout emissions tho) computers always freak out, so a tune would always be good, contact ion at madz28.com
i'm personally going for a cc306... i know its huge for street use, and especially automatic, but i want a big cam... i'll be getting my heads about a month or 2 after the cam too also so its all good...
here is my route... maybe it can give u some ideas
march : pacesetter longtubes
april: cc306 (might get cc305, or hotcam, but i really want cc306)
may: saveup for heads
june: heads save up
july: heads
august: tq verter (3500 stall)
sept: 3.73s
xmas time or jan 05: 12 bolt
and i'll be set
:P
lol, i know that kinda off topic
Old Feb 23, 2004 | 06:50 PM
12SCNDZ's Avatar
Mine's got a CC305...Runs 12.0, and I can drive it anywhere.
All the specifics are in sig, and on web page.
Frank
Old Feb 23, 2004 | 06:58 PM
ponyackn's Avatar
Post
The street manners of the cc305 are tame. It feels stock to me until you stand on it. You should be able to pass CA emmissions too, I did with a pcmforless tune. I really wish I could go bigger but hell, I have enough problems with the car as it is.
12SCNDZ- did you have your heads matched to the cam?
Old Feb 23, 2004 | 07:25 PM
12SCNDZ's Avatar
My head porter knew what cam I was going with. They have a race port job which flow 271 CFM @ .550" with 2.0"-1.56" Manley Pro-Flo valves.
The CC305 is called "mild" so often by people. The fact is, I think too many are overcammed. There's alot of people with much larger cams than mine running alot slower. Also keep in mind that my car runs 12.0 @ 112 MPH with MAC headers, stock suspension, and full weight.
Frank
Old Mar 8, 2004 | 09:03 PM
TransAm1999's Avatar
i'm thinkin of gettin this cam too, ran across this thread via search
does this cam give you a lopey idle? i'm lookin at gettin a cam along with some other junk, but i wanna make sure that if i put a cam in the engine that it SOUNDS like it has a cam in it
and does it pass emissions? if so what kind of HC readings do you get with it?
thanks
