CC on Stock heads
Old Nov 29, 2007 | 01:56 PM
Romero155's Avatar
CC on Stock heads
I did a search and i find mixed replys on what the CC is on the stock head. I read anywhere from 52 CC to 58 CC. Does anyone know the exact specs on it?
Old Nov 29, 2007 | 01:58 PM
speed_demon24's Avatar
~54cc.
Old Nov 29, 2007 | 02:14 PM
marshall93z's Avatar
Yep. Just did mine the other day.
Old Nov 29, 2007 | 02:55 PM
Romero155's Avatar
Gotcha i have another question so im going to buy 383 shortblock and the guy as Probe SRS Dishtop pistons with a dish volume of 20.4cc, it gives a compression of 9.81 on a 58cc head, what do you think the compression would be with the stock 54cc?
Old Nov 30, 2007 | 08:54 AM
That seems like an awful big dish for an LT1 setup. Your other post indicates you now calculate 10.5:1 with a 20.4cc dish. Are you sure you got that right? And, don't guess at the head cc's ot use someone else's results..... measure it on your heads.
Old Nov 30, 2007 | 09:53 AM
CANTONRACER's Avatar
The kit to measure cc's is pretty cheap....buy it and just keep it on a shelf.
Assumptions are the easiest way to screw stuff up.
A few years back I bought a set of heads...I assumed I had 2.08 intake valves in the heads...ordered some pistons based off this assumed knowledge. Guess what happens when you discover your 2.08 intake valve is actually 2.20....luckily I discovered this pre build...but I had to send the pistons back to get them cut to accept a larger valves.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
