CC Pro Mag Rocker Question
Old Jan 16, 2008 | 11:07 AM
G. McDonald's Avatar
I have a fairly new set of CC Pro Mags with about 2,000 miles on them, during which they seemed to work fine (no excessive noise, etc.). I am now putting them back on the engine after pulling the heads to fix a coolant leak that resulted from the porting process (insert cuss word sequence) and have noticed that one of the 16 rockers is somewhat stiff when you try to rotate it about the trunion. It makes no noise and there is no sign of grinding or anything - it is just harder to turn than the other 15. Is there any reason to be concerned? Has anyone encountered this before? There is no outward sign of damage or wear.
Thanks for the input.
Old Jan 16, 2008 | 11:35 AM
BUBBA's Avatar
Make sure the bearings (I'm assuming it has some) are not boogered or missing.JMHO
Old Jan 16, 2008 | 11:38 AM
joeSS97's Avatar
You can buy individual ones from C.C. I would replace it if it were me.They are about $20 each.
Old Jan 16, 2008 | 01:09 PM
Stl94LT1's Avatar
You can send the rocker back to Comp for inspection/repair.
Old Jan 16, 2008 | 01:27 PM
joeSS97's Avatar
By the time they inspect and repair it,it will cost about the same as a new one.And take a lot more time.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Caps94ZODG
15
Aug 10, 2002 07:12 PM
