CC 1.6 RR set screw backed out at high rpm! 2x!
Old Apr 16, 2003 | 01:34 PM
FastGuyJR's Avatar
As the subject says it, my #1 cylinder exhaust valve's roller rocker adjustment has been a nightmare. I've adjusted all the valves to 3/4 turn past zero lash, and I am using brand new Crane OE lifters and a CC 305 cam. On the Comp Cams rocker arms, I adjust the nut to zero lash, go 3/4 turn, then screw down the set screw tightly with a 3/16" alan key. I go WOT to about 6000-6200 rpm for a couple gears, then when I'm idling, I can tell by the tap that my rocker arm has come loose again. The set screw backs ALL the way out (to the very top of the nut). I am thinking I may have to replace the whole nut and set screw, because the threads on the rocker stud look fine. Any suggestions?
Thanks in advance,
JR
Old Apr 16, 2003 | 01:47 PM
GREGG 97Z's Avatar
Maybe try some high temp threadlocker on the set screw.
Old Apr 16, 2003 | 03:55 PM
If the top of the stud is not flat, it may not hold. Is that stud different from any others? Just to rule out the nut, swap it with another and see if the trouble stays in the same place.
Old Apr 16, 2003 | 04:27 PM
FastGuyJR's Avatar
Good idea shoebox, I'll try that next time... in the process I'll check the tips of the rocker studs. I'd rather not use Loctite because if something's wrong there, I don't want to mess up anything else in the process. In the meantime I'll cross my fingers and hope it doesn't break at the wrong time.
Peace,
JR
Old Apr 17, 2003 | 05:00 AM
HungryT/A's Avatar
I'd use some type of threadlocking compound!
Old Apr 17, 2003 | 07:55 AM
The last guy that used threadlocker posted on here that he could not get them unlocked. I don't recommend that. The torsion lock of the set screw should work. Since you only have one that is not staying locked, obviously there is a problem with it, only.
Old Apr 17, 2003 | 08:38 AM
HungryT/A's Avatar
Woh..It sucks.
Old Apr 17, 2003 | 08:12 PM
Janny's Avatar
You might try what I do, and that is once I get the set screw tight I JAM it and the main rocker bolt another 1/8'th of turn or so by reefing on both simultaneously. Those suckers are brutally tight then.
rideordie
Nov 5, 2019 04:52 PM
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
squarehead
Nov 21, 2014 08:02 PM
