Catalytic Copnverter?
Old May 30, 2005 | 08:43 PM
LT1 POWR's Avatar
Are carsound and magnaflow catalytic converter the same thing. And do they pass emmissions tests. Also do they come with air tubes.
Old May 30, 2005 | 09:40 PM
DiabloGT's Avatar
Re: Catalytic Copnverter?
magnaflow makes carsound. yes they pass emissions, and what air tubes are you talking about?
Old May 30, 2005 | 09:56 PM
DavesLT1's Avatar
last I knew our AIR inlets are in the manifolds/headers.
Old May 30, 2005 | 10:12 PM
LT1 POWR's Avatar
if you look on the cat in most pics they have tubes coming out the side of them.
Old May 30, 2005 | 10:19 PM
LT1 POWR's Avatar
And would the Magnaflow HF 3" BIG BLOCK converter work for my aplication. I plan on putting it right after the y-pipe.
Old May 30, 2005 | 10:46 PM
)2overt SS's Avatar
Right after the y-pipe might be too far back.
Cats need to be hot enough in order to function properly.. having it after the y-pipe will heat the cats a lot less.
colts0455
Sep 22, 2015 02:03 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
wbacall
Jun 22, 2015 10:04 PM
