cat location
Old Apr 13, 2003 | 08:16 AM
MuffZ28's Avatar
Question cat location
I have a 96 z w/ a A4. Where is my bank 1 cat and why does it always run like crap after I just wash it?
Old Apr 13, 2003 | 09:53 AM
Bud M's Avatar
Just a guess, wouldn't the bank 1 cat be on the side of the engine that has the #1 cylinder?
Old Apr 13, 2003 | 10:07 AM
EviLBoX's Avatar
Bank 1 is the driver's side. It's kind of hard to actually see the cat since it bolts directly to the manifold, but it's there.
Old Apr 13, 2003 | 10:09 AM
Buttercup's Avatar
Yep, #1 cat is on the drivers side (bank #1) It's kind of hard to see as it's bolted directly to the exhaust manifold.
The most likely cause for it running like crap after you wash it is an ignition problem. Bad ignition wires will short to ground easier when moisture is present. Don't forget to inspect the coil wire either. You may want to look under the hood, with the engine idling, in the dark, to see if they are arcing anywhere. The opti is also very sensitive to moisture so be careful about getting water anywhere near it.
lt1matt
Mar 21, 2015 07:35 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Dec 1, 2014 08:08 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
