Cat. Converter Removal?!?!
Old Jan 15, 2004 | 10:13 AM
AliZee28's Avatar
Exclamation Cat. Converter Removal?!?!
Heyy,
Yesterday i was hearing some noise under the car , i went to the workshop and i was told that its a plugged CAT. Converter. he asked me if i wanna take it off or just get it replaced. I thought i'd take it off to have a better ROAR on my FlowMasterz . and its true i had a better ROAR but i felt some power loss .. so tell me anyone experienced this or im just feeling this and its not true .
RPM changed. i dont really feel shifting as i used to .. i have a transho shift kit installed on my 4l60e
I need your help
97 LT1 Coupe - Rebuilt - TransGo Shift Kit - FlowMaster Mufflers , K&N Filter .
Old Jan 15, 2004 | 10:41 AM
Fastbird93's Avatar
I seriously doubt you experienced any power loss. Odds are you have succumbed to the thing that gets a lot of people. The car sounds louder and tricks you into thinking it lost some power.
If anything, you gained some power. The stock cat can be a big restriction, especially if it's clogged.
Old Jan 15, 2004 | 11:06 AM
gamecockfan04's Avatar
When I put my ORP on I felt like I may have lost a little low RPM power, but it makes it up in the high RPM.
Old Jan 15, 2004 | 12:22 PM
LT4Firehawk's Avatar
You might loose a little TQ on the lower end, but you'll make it up in HP on the top end. When I took the mufflers off my 92 LT1 Vette I lost about 10lb-ft of torque from idle to around 2500, but then I gained right at 10HP from about 4500 on. That was a completely different exhaust system (dual 2.5") of course, but it still gives you a good idea of what may be happening.
Old Jan 15, 2004 | 12:52 PM
Kain's Avatar
You might have experienced some power loss. Your exhaust is so loud now that the computer might pick it up as false knock retard. Do you have the LT4 knock modual? If not, pick one up at your GM dealer; part number: 16214681. It's like $35.
That'll get rid of your problem with knock retard and restore the power you got by adding exhaust and getting rid of the cat.
Old Jan 15, 2004 | 04:38 PM
AliZee28's Avatar
You are right guyz .
Yer right guyz .. i lost TQ on lower RPMs but i gained'em on higher RPMz .
Thanx ..
timmy39120
May 2, 2015 05:12 PM
Apr 16, 2015 09:57 AM
eanhl2004
Apr 4, 2015 12:01 PM
F550maranello2
Apr 1, 2015 11:10 AM
squarehead
Nov 21, 2014 08:02 PM
