The "Cat"
Old Mar 3, 2012 | 06:10 PM
randellb1994z28's Avatar
The "Cat"
Hey guys... for my birthday my parents got me new tips for my z28. well i want an aggressive sound also my the tips are 2.25" inlet and any other muffler has a 2.5" inlet or bigger.... so i was wondering if i took the cat off and put a pipe right there does anyone know if i would loose power.
Thanks Again. Appreciate it
Randell
Old Mar 3, 2012 | 06:59 PM
SupersportLS1's Avatar
Re: The "Cat"
Your check engine light will illuminate.
You will gain power
It will be raspier (louder)
to clear the light get a tune for no cat or o2 simulators.
Old Mar 3, 2012 | 07:02 PM
Re: The "Cat"
If you remove the cat on a 1994, there won't be a check engine light. There are no rear O2s or cat monitoring with OBD-I, so no need for simulators. There is little power to gain just by removing the cat. A cat-back exhaust system would be of more value.
Old Mar 3, 2012 | 11:02 PM
Re: The "Cat"
Listen to Rob/Shoebox!
Old Mar 4, 2012 | 01:12 AM
Re: The "Cat"
A borla cat-back is the main goal but... me being a junior in high school, it's not quite in the budget right now so i think that i will take the cat off and then put a cat-back on in like a year or so thanks guys
Randell
Old Mar 6, 2012 | 02:26 AM
canuck94z28's Avatar
Re: The "Cat"
I agree that removing the cat is a bad idea.Back in 2010 i removed my Walker Hi flow cat & installed a Mac off-road pipe(s**** mod)& promptly lost 2 tenths! from my 60ft. times.My throttle response also felt worse.Unless your cat is plugged solid should you replace it & then you should be looking @ a Walker/Random Tech hi-flow unit!
Old Mar 6, 2012 | 05:18 AM
Re: The "Cat"
There is no reason you would lose power by removing the cat.
Old Mar 6, 2012 | 09:22 AM
Re: The "Cat"
I took it off and i most definentaly did not loose power she throws me in the seat harder now, so no you do not loose power.
Randell
