Castrol Syntec 0w-30 German...Good for LT1?
Re: Castrol Syntec 0w-30 German...Good for LT1?
First of all GM does not reccommend use of 0w-anything in their engines for a good reason...the stuff is just too thin !
They do recc. 5w30, which I find far too thin still.
I won't run ANYTHING thinner than 10w30 in ANYTHING including a LAWNMOWER, and in my LT1, which had over 265,000 original miles on an untouched LONG-BLOCK before it puked a head gasket, was ran exclusively on Red Line or Royal Purple 20w50 EVEN IN MICHIGAN WINTERS. Oil was changed roughly every 15,000 miles, of which generally 90% were long highway drives (over 50mi each way to work at the GM Tech Center where I am an engineer)
My 383 build will be using the same....I can't argue with 265,000 miles
EnerjetF67 is offline Report Bad Post Reply With Quote
A/G
Ya must have completely missed this post.
Might want to read it!!!!!!!!
He is a GM engineer.
Build ya an engine with 2.5-3.0 thou on the rods and 3-3.5 on the mains and put in some 0-10 weight(Royal Purple has it) and see where your OP is at any time.
That statement is without foundation and irrelevant. It is a foolish statement! It is missing the point.
Try it one time and see where it gets ya with thin oil and OP. It is the same as trying to put 0 weight in a 100,000 mile engine.
With wear=more clearance.
'm not asking to find out, I'm doing so to see if you know what it does. I'm not convinced you do. The ideal oil is one that does not energize the by-pass on a cold weather cold start, and increases it's adaption as the temp increases. That is the purpose for 0W(whatever).
A 20 weight oil WILL NOT open the OP bypass at a cold start on a 70* day.
Ya thinking backwards or something. Must Be
A/G
Originally Posted by A/G
Your mind is made up, so I did not post in an attempt to convince you.
There are a lot of different engineers at GM with different backrounds.
I have run 0/20 in some drag engines that I built to run it so convincing me is not an option. I don't believe in running it in a 2/3rd's worn out engine and letting the OP suffer--- which it does. Ya can tell everybody else how wonderful it is in a high mileage engine NOT built for it, but not me.
Real good way to cause an overhaul.
Is there a graph or anything stating proper oil temps vs oil weights?
I have a oil temp gauge and when cruising around town with the 4.10's and keeping the rpms no higher then 3k when shifting and a cruising rpm of 2k my oil temps can hit 220-240 is this too high? And will a thicker oil lower the temps?
Right now im running 0-30 castrol.
You are kidding right? There were guys that worked on LTx PCM software that weren't knowledgeably aware of what was going on in other areas controlled by the same PCM. Sure, all GM engineers know what other engineer know. One close knit family. LOL You do not cease to amaze me racer.
I have run 0/20 in some drag engines that I built to run it so convincing me is not an option. I don't believe in running it in a 2/3rd's worn out engine....
You have not been paying attention. Not anybody least of all me in this thread, stated anything about using 0W20 in the engine, except YOU.
No, but 0/30 GERMAN or whoever is damn close to the same thing.
Thinking backwards again.
Know some that know something about every facet of the operation.
AMAZE on there.
Originally Posted by Joseph Overton
Did I see right that racerdude allowed 15k to roll by before a oil change
just wondering if that was a typo or not...
gotcha you quoted someone else... sorry
That's to damn long in one of my engines,or my personal 'maro. Might work for some folks but not here.
Who was you referring too?
An engineer racer figured knew something of every other engineer's job at GM. That qualified the guy to be an oil expert.
You see, racer likes to pick and choose what someone else states if it suits his fancy, and ignores what he doesn't like.
Post #28
Post #29 quoting above...Then this post...
I think you mean your facts. To quote a line from Purple Rain, (racer) "I like you, you make me laugh."
Sometimes it pays to keep um laughing-- makes um wonder what ya are up to,HUH.
Originally Posted by Injuneer
And, multi-viscosity "conventional" motor oils will often be "thinner" when the range of viscosities is widened (0W-40 vs. 10W-40), due to the reliance on long chain polymer viscosity enhancers. But true synthetics will show very little difference as the viscosity range covered by the specifications is widened.
