Casting numbers ?
Casting numbers ?
Are the casting numbers different only for different parts?
for example, the number for a set of heads is different from the number for a control arm;
Or are would the casting number be different for the same part?
for example, set one of heads that roll off the line have a different casting number than set two of heads that roll off the line.
