Cars running rich. Why?
I checked the plugs today and they were jet black. After the headers went in the car lost power, it won't spin them on a 1 - 2 shift anymore
. I was wondering what the problem might be? The bolts are tight and there dosn't seem to be any leaks although i am useing cheap paper gaskets.
If you have a good bit of miles on them, or you don't know how old they are then you should replace them. Go with the stock ones. Around $100 for the two you need. I found the ones I'm getting at www.lakechevrolet.com or I'll try to get ahold of Jason Cromer.
I think i'm going to do that, first though i'm gonna try to just disconnect them and see if that helps out at all. I was wondering though, when I had the exhaust tack welded together I had them make O2 extensions. The extensions were from the O2's to the PCM, not an extension of the pcm wires. Could that cause it?
Originally posted by david97gsxr
o2 sensors are 70+shipping at gmpartsdirect.com
shipping from them is a little expensive, so it'll probably be about 15 bucks.
p/n 25312184
edit: that's 70 for both of them
p/n 25312184
ro2207
Dec 4, 2014 06:18 PM
