Spark Plugs
Old Mar 24, 2004 | 11:14 PM
blahster's Avatar
Spark Plugs
I need to get some new plugs and wires. Which ones to get? cost? And how hard are the plugs and wires to change? I have not done them on my Z before. I remember on my 96 3.8L they were a hassle cuz i had to get under the car and take off the exhaust and blah.... Thanks yo
Old Mar 24, 2004 | 11:36 PM
Kevin_97's Avatar
NGK TR55 are one of the most common plugs, their what I'm running...
Old Mar 24, 2004 | 11:41 PM
ram air camaro's Avatar
there pretty hard if you have stock manifolds but allot easier with most headers. just do one by one.
Old Mar 24, 2004 | 11:56 PM
jtk's Avatar
jtk
stock replacement wires and stock sparks. if you have to go with aftermarket, carquest wires and delco plat plugs (delcos are OEM)
Old Mar 25, 2004 | 12:01 AM
LimitedEd1LE's Avatar
Another vote for the NGK TR55's. I also have the Taylor Spiral Pro wires. Great combo and not too expensive. They plug access is crappy if you still have the stock manifolds.
Old Mar 25, 2004 | 12:02 AM
RedHottG2's Avatar
TR55s are the way to go, and if your not use to changing plugs/wires in our cars be ready because it's gonna be a real PITA.
Old Mar 25, 2004 | 12:14 AM
SpeC's Avatar
every1 here will tell you stock wires with NGk-TR55 plugs.
The mechanic told me that i should stick with with stock ACdelco plugs and not go with any other afermarket 1s. He said they create problems. i dunno cuz i never got it done though.
(prob ACDelco platinum plugs will be good)
Old Mar 25, 2004 | 03:47 AM
jkipp84's Avatar
If you're going to get platinums, don't get AC Delco's. Do some searches, there are tons of posts from folks like me who've had the little platinum pucks disappear after a few thousand miles. Once the puck is gone, the gap is off and just where does that puck go? Somewhere in the engine. Very nice - and they're $5 and change per plug (here anyway). I've had the $2 Bosch platinums (not +anything) for a year and a half now. They're doing a great job. More importantly, I don't have to worry about whether parts of them disappearing in the cylinders.
For just about every other stock replacement part, AC Delco is the way to go.. but at least consider some alternatives for the plugs.
Old Mar 25, 2004 | 11:18 AM
blahster's Avatar
I was also thinking about MSD wires...maybe RED in color? anyone got any opinions on this? or maybe suggestions on some other wires that might be red? Thanks
Old Mar 25, 2004 | 01:38 PM
soontobeGN's Avatar
I just put autolite plats in, they seem fine. anyone else have experience with them?
Old Mar 25, 2004 | 02:46 PM
Eddie Z-28's Avatar
Should I get aftermarket wires or just stock ones from the dealership? Please help.
Old Mar 25, 2004 | 02:57 PM
valter's Avatar
NGK TR55 High-temp wires, your choise, don't get too cheap on them. If you have proper tools - easy to do. Much less crawling under car then with 3.8
Old Mar 26, 2004 | 02:02 AM
Fatdog's Avatar
Cool
Might do a search (top of this page).
Old Mar 26, 2004 | 05:04 AM
Got-LT1?'s Avatar
Hey man, if you ever plan on doing headers... might as well go with an OVC (Over the Valve Cover plug wires) kit now and get it done with... Its less than $100 from thunderracing.com, or you can piece together your own from jegs. Also I have heard nothing but great things about the NGK TR 55r plugs from lots of people, thats what I plan on running soon..
Good luck...
Old Mar 26, 2004 | 04:00 PM
SweetZRag's Avatar
I just installed Taylo Spiral Pros (8mm) and they fit fine in the stock routing retainers. I used the Bosch Platinum 4 plugs because they worked so well in my Blazer. Had this setup for about a week now and it made a nice difference.
