Cars Been Sittin Awhile
Hey guys about to pull back out my camaro but i havent even started it since prolly September, is there anything i should do, whole ignition is new so i wont need plugs or anything, im guessing drain the gas and change the oil but just wondering if theres anything else i should do.
Did you put a fuel system treatment in the gas tank? I'm sure it is still fine, it hasn't been too long of a time period. Personally, I would change the oil, probably air up the tires too. Once you get it going and drive it around for awhile, I would look give it a good look over for any leaks.
If your battery is low, better charge it up. Advise you get one of those cheapie, battery minders that turn off once the battery is charged. Running around in a low battery won't do much to charge it up---good thing it's an M-6. JMHO
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
