Carbon build up on my AFR heads
Old Mar 28, 2007 | 10:10 AM
roSSco's Avatar
I spent last night cleaning up my AFR heads. They had the carbon buildup of 250,000 miles and only went 20,000. The old motor ran poorly. (duh).
I put one of them on the engine but may pull it off to clean the intake valves. You can see them through the intake runner and they are super nasty. That can't be a good thing.
I used a wire brush on a drill to clean the combustion chambers but there is still some carbon around the valves. Should the valves be removed and all that crap cleaned off?
Old Mar 28, 2007 | 10:14 AM
Javier97Z28's Avatar
Moderator
Send 'em to a machine shop and have them disassembled and hottanked.
Old Mar 28, 2007 | 10:49 AM
speed_demon24's Avatar
And put a catch can on there when you get it back together to keep oil out of the intake which should help with the carbon buildup.
Old Mar 28, 2007 | 08:12 PM
MachinistOne's Avatar
AFR does not seal their rocker studs out of the box, you might be sucking oil out of the top of the head into the port.
How many miles are on the bottom end?
Old Mar 28, 2007 | 09:19 PM
roSSco's Avatar
I bet you're on to something! I removed two of the intake valves today and it was all I could do to remove the build up w/a wire brush on a drill.
30,000 on the bottom end.
Old Mar 28, 2007 | 09:24 PM
Gasket remover took the carbon right off my pistons, you might want to try that.
Old Mar 29, 2007 | 08:26 PM
roSSco's Avatar
I checked each rocker stud to be sure they weren't leaking into the intake. I did it by filling the threaded hole with brake cleaner and looked for leaks.
None found.
I guess it happened (the fouling) when the fuel return line was plugged.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
