carbed lt1?
Old Nov 27, 2007 | 12:10 AM
suicidal racing's Avatar
carbed lt1?
anyone got a parts list of what all is needed to go with this setup.
i know i will need the gmpp lt1 intake.not sure what distributor i will need to use.
also anyone got any pics of this setup.
how hard is it to convert over? i'm a carb guy and fi gets on my nerves so i'm looking to go that way.
thanks for the help
Old Nov 27, 2007 | 06:09 AM
93BlackTA's Avatar
Id like to know also for another project engine that i have
Old Nov 27, 2007 | 07:29 AM
cnorton's Avatar
In addition to the intake, GM sold a block-off plate for the later design optispark front cover. It not only seals the hole through which the opti connected to the camshaft, it has an integral timing mark for setting the timing with a light. It would require the use of a balancer that had a TDC mark or that was marked in degrees around the circumference. The block-off plate attaches to the front cover using the bolts that originally secured the opti. A standard small-block distributor will fit through the hole in the usual location at the rear of the manifold. Once you get this far, setting up the rest of the changeover will be pretty much like a regular, carbureted small block engine.
Old Nov 27, 2007 | 01:17 PM
thanks.
i didn't know about the block off plate..i was thinking of just leaving the opti there.
also if some one bolted on just the intake and carb would it be legal for the bolt on record?
Old Nov 27, 2007 | 02:53 PM
reamo04's Avatar
Originally Posted by suicidal racing
thanks.
I don't see why not?
Old Nov 27, 2007 | 05:23 PM
some people have diff ideas of what bolt on is.
i seen they swaped valve springs and roller rockers on the record holding car..not sure if people would think bolting on a carb intake an carb would be legit.
i guess you get the bolt on record aslong as you dont mod the heads,gasket match the intake to heads,mess with the cam or anything in the short block or pull the heads off to put a thinner gasket in to raise the compression.
Old Nov 27, 2007 | 05:26 PM
reamo04's Avatar
the carb. intake isnt going to mess with performance that much anyways, and adding on a carb is no diff. than adding on a throttle body, so, id say its fair game. Contact shon herron ask him since hes the current record holder lol
Old Dec 6, 2007 | 07:28 PM
tomcowle's Avatar
I agree, this should have no problems with being a "bolt-on" car.
I made the switchover on mine, so far I'm really happy with mine.
Old Dec 7, 2007 | 01:29 AM
v8 FC's Avatar
mine didn't last very long! i was not to happy with the carb setup so back to efi for me! good luck with it
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
