94 lt1 with obd 1 port?
Old Dec 7, 2007 | 02:36 AM
95lt188chevytruck's Avatar
Well I am confused did they make a 94 lt1 with an obd 1 port because I have a MAF and it has a standard obd1 port. I guess what I really am trying to figure is if I can put a tune on my computer because I don't want to spend the money for T/C if I can't. How can I tell if its a 93 or 94 computer?
Old Dec 7, 2007 | 03:52 AM
SS RRR's Avatar
I'm pretty confident it's not a '93. Don't think the PCM's are interchangeable w/ the PCM harness. The '93's contained the chip which needed to be burned whereas '94 is has a programmable chip via diagnostic port under the drivers side kick panel.
Just FYI I'm pretty sure OBDI has been around much longer than '94.
Old Dec 7, 2007 | 05:32 AM
Yes.... all 1994's are MAF, with an OBD-I PCM and a 12-pin OBD-I ALDL connector. Your setup sounds completely normal.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Roadie
Feb 16, 2015 10:34 AM
