carb 350 swap?
Old May 1, 2011 | 07:24 PM
twistedbowtie's Avatar
Question carb 350 swap?
i have a 95 camaro z28. 6speed. im haveing alott of motor problems and was wondering if itspossible todo i carb swap. i have a built 70s 350 so itd be easier to just drop that in.
how hard is it todo if possible?
anyone have pics?
thanks.
Old May 2, 2011 | 04:23 PM
Re: carb 350 swap?
any ideas?
Old May 2, 2011 | 04:29 PM
englundjd's Avatar
Re: carb 350 swap?
yes you could put that in there but there is something with clearance with a regular distributor, maybe someone with this kind of experience could chime in?
Old May 3, 2011 | 12:11 PM
ZZ's Avatar
ZZ
Re: carb 350 swap?
It would suck dropping the engine to change a distributor cap.
Old May 3, 2011 | 03:49 PM
bw_hunter's Avatar
Re: carb 350 swap?
I believe the clearance problem is with the standard FI intake manifold and a standard HEI distributor....it may fit fine with the carb intake setup.
Old May 3, 2011 | 09:19 PM
Re: carb 350 swap?
thanks guys. i have decided its a bad idea to do away with the fuel injection lt1 setup.
can i use the short block from the carb. 350? do the bolt pattern match the lt1 heads?
Old May 4, 2011 | 05:06 AM
bw_hunter's Avatar
Re: carb 350 swap?
This Is an even worse idea. Lt1 engines are reverse flow cooled, the standard chev sb is not. You can much more easily carb an lt1 than adapt lt1 heads to an old small block....
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
dfarr67
Apr 10, 2015 07:44 PM
veryslowfbody
Aug 22, 2002 04:31 PM
