Car Won't Stay Running !!!
Old Oct 8, 2011 | 01:40 AM
  #16
Fatdog2's Avatar
Re: Car Won't Stay Running !!!
Maybe you o2 sensors are not getting hot enough to send info to the computer.read this somewhere.Might do a search.Hope this helps.(o2 heaters?).
Old Oct 8, 2011 | 08:31 AM
  #17
raroz28's Avatar
Doubt it.
You can unplug the o2's and the car will still run.
Since it's doing it all the time, I would recommend checking the fuel pressure. Get a cheap harbor freight gauge and connect it to the schrader valve on the back of the intake.
Report back with your results. You should be at about 43 PSI.
Old Oct 8, 2011 | 10:03 AM
  #18
Pullngz's Avatar
How did the car run BEFORE, the exhaust and opti/wires were installed?
Old Jan 14, 2012 | 05:07 PM
  #19
Smith.justin51's Avatar
Any luck fixing it? My cars doing the same thing.
Old Jun 26, 2015 | 05:19 AM
  #20
weigh2fast4u's Avatar
BUMP PLease. My car gets warm and just SHUTS off. no stubbling or any warning. like i reach up there and Turn the key off..... Ive changed three fuel pumps, and the ICM. summit is bringing me a new MSD coil today.... Ive been scratching my head for over a week now.
Old Jun 26, 2015 | 07:17 AM
  #21
At any point have you scanned if for codes?
You need to add info to your signature... like year of the car.
Old Jun 26, 2015 | 07:20 AM
  #22
I haven't. will it throw a code without a light coming on?
Old Jun 26, 2015 | 07:29 AM
  #23
How much voltage should be at the wires going into the fuel tank? I can't find that on shbox
Old Jun 26, 2015 | 08:24 AM
  #24
If you mean to power the fuel pump, it's 12v. Yes, it is on shbox.
Old Jun 26, 2015 | 08:51 AM
  #25
Unplugged opti harness. Purple and white wire terminal was corroded. High resolution. hopefully it will run now thanks to some vinegar. we will see
Old Jun 26, 2015 | 10:38 AM
  #26
Yas.
DTC 16, for loss of low resolution pulse signal from the cam position sensor in the Opti, does NOT turn on the SES light, but it shuts down the fuel system (pump and injectors).
97SSdude
Dec 31, 2014 07:43 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
MJ_Z28
Aug 7, 2002 07:15 PM
