Car won't start. Trouble codes I don't think has anything to do with it.
Old Feb 18, 2009 | 09:26 PM
djm_e22's Avatar
I can't get my car to start and the codes I pulled up were P0135(Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 1) P0530(A/C refrigerant pressure sensor circuit) and P1667(Reverse inhibit solenoid control circuit). The P1667 may be an old code I never deleted.
Anyhow I thought that a Nonworking oxygen sensor would just cause it to stay in Open Loop, which the car should still start correct? I have no idea how the A/C refrigerant pressure sensor circuit would have anything to do with the car not starting. What do you guys think?
Old Feb 18, 2009 | 09:56 PM
maverickmk's Avatar
I would have to agree, with those codes it should start, start with the basics, is it getting gas? is it getting spark?
Old Feb 18, 2009 | 10:03 PM
djm_e22's Avatar
I'm pretty sure it is not getting spark, cause at first it would start for about 1 to 2 seconds. Now it won't start at all. Also I can hear the fuel pump starting. But if it is not getting spark shouldn't I get some sort of ignition code or could the code just not have popped up yet.
Old Feb 18, 2009 | 11:30 PM
If the ignition problem is on the high voltage side, between the coil and the plugs, there are no codes that would be set, other than a misfire code if it was running. There are codes for the IC Module, and for the optical section of the Opti, but that's all.
Old Feb 19, 2009 | 06:44 AM
djm_e22's Avatar
The only thing that would be between the coil and the spark plugs would be the distributor, correct? or is there something else I'm missing. By the way my optispark is a new gm one with maybe 2000 miles on it.
Old Feb 19, 2009 | 05:01 PM
Coil, coil wire, Opti cap/rotor, plug wires, plugs. All of those parts are on the high voltage side and do not set a code (unless they cause a misfire).
Old Feb 19, 2009 | 07:00 PM
djm_e22's Avatar
thanks a bunch man!!
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
fpete1992
Dec 11, 2014 03:51 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
