Car won't start, ticking sound
Old Aug 19, 2005 | 06:09 PM
infinitebird's Avatar
Hoping some of you guys can help me out here. I just changed my oil last night. Had no problems with it. Started it up afterwards, verified pressure then rechecked oil level. No issues.
I go out to start the car today and it won't start. All I hear is a loud ticking noise. It does not turn over at all, I just get this noise whenever I try to start it.
Car appears to be getting power. I can still turn on the headlights.
I don't really get it at all. Nothing was changed or modifyed except the oil and oil filter, and like I said it started up fine after that was all finished.
Any ideas?
Old Aug 19, 2005 | 06:13 PM
moparman's Avatar
Re: Car won't start, ticking sound
Could be the battery, or a loose cable.
Old Aug 19, 2005 | 06:16 PM
1racerdude's Avatar
Starter
Old Aug 19, 2005 | 06:20 PM
How could it be the battery if the headlights still work?
Old Aug 19, 2005 | 06:21 PM
Birdman7389's Avatar
Your starter draws much more power than your headlights. Go out and try to jump-start it.
Old Aug 19, 2005 | 06:26 PM
1racerdude's Avatar
Turn your headlights on and try to start it. If the lights go out or dim badly its the bat,if not its the starter.
Like was said jump it and see.
Old Aug 19, 2005 | 06:28 PM
Ok yeah that makes sense. I will try that.
Old Aug 19, 2005 | 06:30 PM
Cmr0z28's Avatar
Either your battery or starter solenoid.
Old Aug 19, 2005 | 06:31 PM
I tried that and the lights didn't go out but they did dim a little bit at the same time as the ticking sounds.
I'm the only one at the house right now so I will have to wait a few hours till someone else gets back before I can try and jump it.
Old Aug 19, 2005 | 06:33 PM
Also, I have a voltmeter/ammeter. Could I use that to test the battery somehow?
GT KILLER's Avatar
I had a problem earlier in the summer with not starting.....it didn't even tick. I got absolutely nothing, though my headlights still worked. They dimmed when I tried to turn the engine over. I checked my battery connection and it was loose just a tiny little bit. I also think it had something to do with the crap battery that was in the car when I bought it.
It sounds like it may be a problem with your battery and/or the connection.
Old Aug 19, 2005 | 06:42 PM
1racerdude's Avatar
Smack the starter with a hammer and see if ya can get it to start,maybe more than once,smack it and try it, smack.....brushes may be stuck and ya can jar them loose to make contact.NOT a permanent fix
Old Aug 19, 2005 | 06:53 PM
Thanks for all your help guys. I'm definitely starting to think it's just the battery. The last few times I turned on the lights they came on but stayed down (motor did not activate). Then they finally came up but did slowly.
Also I just checked the battery terminals with a voltmeter and it varied a little but the max I got was 8.3 volts. Isn't that way too low?
Old Aug 19, 2005 | 07:06 PM
moparman's Avatar
The voltage is way low.
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
